03-27-2015, 11:38 AM | #1 |
What is this carburetor car from?
Dear Friends!
I have this carburetor installed in a Ford V8 350, but someone told me that this is not the original one. Can you help to identify this carburetor? Thanks Hary
I love my Ford V8 1946! Harylufa! |
03-27-2015, 11:52 AM | #2 |
Re: What is this carburetor car from?
'49-ish Mercury flathead, I believe! DD
03-27-2015, 12:08 PM | #3 |
Also '49-'51 Lincoln or big Ford truck.
The one in the pic appears to have been converted to manual choke.
03-27-2015, 12:10 PM | #4 |
Hi all!
I really appreciate your help, this carb is installed in a Ford V8 350, called here Fase 2. Do you know this engine? Hary
03-27-2015, 12:23 PM | #5 |
Sometimes also referred to as "towering infernos". DD
03-27-2015, 12:43 PM | #6 |
'52-'53 MERC'S were the towering infernos'
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 03-27-2015 at 04:22 PM. |
03-27-2015, 01:10 PM | #7 |
"Tea Pot" Holley 885. Trucks have the manual choke set up but a lot of them have governors. Early 1949 Mercs & Lincolns and a lot of trucks used a ball tip on the throttle arm and the later ones had the drilled hole for use of the clip retained type throttle rod. On the top of the accelerator pump relief, (the part that is the highest point on the top of the shroud) there should be the little numbers that are the date code for the carb. It will have the number of the month stamped next to a smaller raised cast in number that represents the last two digits of the year of manufacture.
03-27-2015, 01:46 PM | #8 |
03-27-2015, 01:50 PM | #9 |
The carb in the pic looks like the remains of a governor on the flange.
Martin. |
03-27-2015, 03:46 PM | #10 |
If you mean the arm at far bottom right, I think that is a truck-style manual throttle arm.
'52 F-1, EAB flathead |
03-27-2015, 03:58 PM | #11 |
03-27-2015, 05:34 PM | #12 | |
I hace some pic from engine. Here we called Ford fase2. I need a manual how to assemble the engine. Thank Hary
03-27-2015, 05:39 PM | #13 | |
I really appreciate this info, it is very valuable for me. It is the first time I see this kind of carburetor. Nowadays I am studyng in a course of Automotive mechanic. Thank you very much Hary
03-27-2015, 05:51 PM | #14 |
I think the Argentinian fase 2 (phase 2) engines were a development based on the Y-Block. Not heard of a 350 though.
Mart. |
03-27-2015, 06:46 PM | #15 |
I think the Ford 350 is like an F350 1-ton truck. The fase II heads have a more conventional split for the intake manifold and the exhaust was also improved but I believe it is still a 292 cubic inch motor.
Ford of Argentina used this motor for a lot longer than the USA and they improved it a lot too. |
03-27-2015, 07:07 PM | #16 | |
This is my doubt, I thought that would be 292 cubic inch motor. I need to find a manual from this engine. Thanks Hary
03-27-2015, 07:13 PM | #17 | |
What is the original carburetor from this engine? Thanks
03-27-2015, 07:57 PM | #18 |
So you putting a yblock in your 46? interesting setup. Always something different on these old fords.
I think those merc carbs are around 100 cfm. I think the early yblocks used a 94 Holley before moving to the teapot (tower of inferno) carbs. I put a 390 2 barrel on a 292 and it's been great. Just enough. What's your plan? Last edited by Tinker; 03-28-2015 at 07:23 AM. Reason: 94 not 97 |
03-27-2015, 07:59 PM | #19 |
Cool thread.
Some ques on the yblock which it looks like to me. http://ford-y-block.com/Block%20identification.htm Maybe the 350 nomenclature is based on the sbc Chevy craze. Or not. Last edited by Tinker; 03-27-2015 at 08:04 PM. |
03-28-2015, 07:43 AM | #20 |
100 cfm? Gota be a typo?
Martin. |
