02-04-2015, 01:59 PM | #1 |
Ring gear and pinion set and rear axle shaft
Hi
Im looking for the Ring Gear and Pinion set (standard) Ratio 3.78:1 Ring = 34 teeth Pinion = 9 teeth I also looking for a couple (left and right) Rear Axle Shaft and gear for the same car Is a Ford Model A 1930 Thanks |
02-04-2015, 05:45 PM | #2 |
Re: Ring gear and pinion set and rear axle shaft
Try Bert's in Denver. 1-800-321-1931, but I don't know if that number will work when dialed out of the country.
02-04-2015, 09:52 PM | #3 |
Thread Tools | |
Display Modes | |
