Old 02-12-2020, 02:07 PM   #1
STAN WHITE
Default 34 ford rear differential cage bearing grease
Trying to find the long fiber wheel bearing grease. It is recomendid for Cage roller rear end Bearings. Can anyone help ?? Thanks Stan
STAN WHITE is offline   Reply With Quote
Old 02-12-2020, 02:46 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 34 ford rear differential cage bearing grease
Try the Model T site ,or the Tram enthusiasts,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 02-12-2020, 02:51 PM   #3
brsturges
brsturges's Avatar
Mac Van Pelt sells it. vanpeltsales.com
brsturges is offline   Reply With Quote
Old 02-12-2020, 02:54 PM   #4
tubman
tubman's Avatar
Stan,
Are you still interested in condensers? I have gotten 2 empty PM's from you in the last couple of weeks.
Sorry to hijack this thread, but I don't want to leave ya' hanging.
Tubman
Old 02-12-2020, 02:55 PM   #5
19Fordy
19Fordy's Avatar
Here' the grease that's used on 40 Fordd rear wheel bearings. I think 34 is the same.
https://www.google.com/search?q=sta+...hrome&ie=UTF-8
Old 02-12-2020, 03:44 PM   #6
Mart
Mart's Avatar
Whoa, guys. The cage roller in the rear differential is lubricated by the axle oil.
Unless you mean the rear wheel bearings which are roller type and within the hub. Then the question is valid.
Mart.
Old 02-13-2020, 10:07 AM   #7
Terry,OH
Terry,OH's Avatar
NAPA sells the Sta-Lube SL-3131 for the rear wheel hub bearings. If they do not have it on their shelf they can get it overnight, in most cases.
Old 02-13-2020, 10:51 AM   #8
19Fordy
19Fordy's Avatar
Sta Lube 3131 is used on these type bearings in the rear wheel hub, called rear wheel bearing. Looks like this:
https://www.speedwaymotors.com/Speed...yABEgJN9PD_BwE
