07-16-2019, 07:28 PM | #1 |
Cast steel vs aluminum crab distributor
Is one better then the other ? Why the different versions and is one more desirable?
07-16-2019, 07:58 PM | #2 |
Re: Cast steel vs aluminum crab distributor
Personally, I prefer the iron bodied unit. For one, the bore of the piston brake plunger is lined with a bronze bush
07-16-2019, 09:16 PM | #3 |
Steel was generally used on commercial ( truck) engines
Aluminium generally passenger cars. |
07-16-2019, 09:40 PM | #4 |
Interesting
07-16-2019, 09:48 PM | #5 |
I usually see the cast iron ones in military surplus boxes. The bushing for the piston is nice.
07-16-2019, 09:56 PM | #6 |
07-16-2019, 10:17 PM | #7 |
I have two aluminum and a cast. Presently the cast is installed and so far so good.
07-17-2019, 03:11 PM | #8 |
Cast was 1942 cars and trucks.
07-17-2019, 06:01 PM | #9 |
The cast iron distributors are the way to go the bronze bush in the vacuum brake gives a better reading to the worn aluminium vacuum brake housing. Every aluminium distributor i have worked on I have found the vacuum brake housing is worn and this applies to the early bell types too, more than the cast iron housing with the bush which could be replaced if necessary to give the piston better sealing.
07-17-2019, 06:12 PM | #10 |
Can't be too hard to bore and install a bushing in the alum ones.
07-17-2019, 06:55 PM | #11 |
Interesting reading and good to know. Thanks to all for the excellent replies
07-18-2019, 06:29 PM | #12 |
Fred hit the nail on the head, bore/hone the aluminum one, install a bronze bushing.
07-18-2019, 07:03 PM | #13 |
