Old 08-17-2018, 10:58 PM   #1
Ray baker
Default Speedometer cable keeps coming loose
Put a new speedometer cable in my car and it keeps coming out of the speedometer. The speedometer was just serviced . Is there something I can use to keep the cable in the speedometer.
Ray baker is offline   Reply With Quote
Old 08-17-2018, 11:16 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Speedometer cable keeps coming loose
Do you mean the nut that holds it is unscrewing?
Old 08-17-2018, 11:26 PM   #3
J Franklin
J Franklin's Avatar
Give it a dab of blue Locktite.
Old 08-18-2018, 09:16 AM   #4
katy
katy's Avatar
Squeeze the nut a little bit, just enough to give it a bit of a bite.
Old 08-18-2018, 09:29 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
SQUEEZING a nut is TERRIBLY PAINFUL---NLOL
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-18-2018, 09:42 AM   #6
Big hammer
Maybe the inter cable is to short and it is coming out?
get a bigger hammer tap done
Old 08-18-2018, 10:20 AM   #7
Ray baker
The inner cable comes out after a few bumps. When I insert the inner cable it seems to fit ok and. Seams to fit just fine. I thought about a drop of lock tight.
Old 08-18-2018, 04:01 PM   #8
Badpuppy
Is the cable well lubricated? If the inner cable rides against the housing it could twist, thus shortening the overall length.
Badpuppy is offline   Reply With Quote
Old 08-18-2018, 04:30 PM   #9
redmodelt
redmodelt's Avatar
If the "inner cable" is coming out, then it is too short or installed the wrong way. The end with the flange would be at the top. Some might use a washer under the crimped on drive head.
Old 08-19-2018, 10:27 AM   #10
Bruce Newbery
I had the same problem on 3 cables I have bought in the last 3 year’s. It is because the cables are made to short. The stuff is just not made to spec. All I did on my 28-29 was remove the drive gear from the torque tube ,clean the grease from it and make a spacer that will fit inside the speedometer drive gear out of a nail or something that will act as a spacer. Mine had to be 1/2 a inch long. Put the spacer in and problem solved.
Bruce Newbery is offline   Reply With Quote
Old 08-20-2018, 07:36 PM   #11
redmodelt
redmodelt's Avatar
Talked to my Model A grue today, there were some cables made a few years back that were too short (oval type speedo without the thrust washer at the speedometer end). They need an added plug in the driven end (at the drive shaft). Some kits came with a plug to install down there.
