Old 05-10-2015, 05:41 PM   #1
cohammer60
cohammer60's Avatar
Default Long shift to third .
Looks like my transmission is on the way out . Shifts from first to second at about 18 mph and into 3rd about 24. Some times it long shifts into third. I changed the filter screen and made sure fluid level is perfect at hot idle . Is there really any kind of mystery oil that really helps ? Or any other suggestions for my 1974 bronco with C4 automatic.
cohammer60 is offline   Reply With Quote
Old 05-10-2015, 05:51 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Long shift to third .
One suggestion; check for vacuum leaks in the line going to the vacuum modulator or possibly the Vac Mod is bad itself. Cheaper to check that a new trans.
Check band adjustment?
No mystery oil...
Old 05-10-2015, 05:55 PM   #3
Motorhead6
Lubegard friction modifier is a great product and the only one I recommend. I use it in all of my rebuilds. If this stuff doesn't improve the shift quality, you're going to have to rebuild it. You have to use the stuff in the black bottle in a silver and black box. It's about $19.00 in parts stores and available on e-bay for less than that.
LUBEGARD Highly Friction Modified ATF Transmission Additive Fluid BLACK 61910
Motorhead6 is offline   Reply With Quote
Old 05-10-2015, 08:16 PM   #4
cohammer60
cohammer60's Avatar
Thanks for that information . I will check the vac module and hoses , I changed all the rest of the hoses and they were rotten , then the lube guard sounds good.
Old 05-10-2015, 09:34 PM   #5
Alaska Jim
Alaska Jim's Avatar
can't remember if the bands are adjustable on this trans., if so try and adj. them. It may help.
Alaska Jim is offline   Reply With Quote
Old 05-11-2015, 06:59 PM   #6
Y-Blockhead
Yes bands are adjustable on a C4... I mentioned that in my post above.
Old 05-11-2015, 11:01 PM   #7
Alaska Jim
Alaska Jim's Avatar
Sorry, must have not completely read the post. I always value your knowledge.
Old 05-15-2015, 11:04 PM   #8
Y-Blockhead
Just shows great minds think alike...
Old 05-20-2015, 03:07 PM   #9
hoss73ford
I had that happen to me twice, a C-4 on a Mustang and a C-6 on an F150. I put a quart of Trans X additive in the Mustang ( the additive was new on the market in 1988 when this happened) It cured the problem for about 6 months and by then I was ready to have it rebuilt. Did the same for the F150.
hoss73ford is offline   Reply With Quote
Old 05-21-2015, 03:05 PM   #10
a4278v
make sure your throttle kick down linkage is on and functioning correctly
a4278v is offline   Reply With Quote
