Old 05-13-2014, 07:43 PM   #1
cohammer60
cohammer60's Avatar
Default Body work
Can some one tell me what has to be done to correct this problem? After taking off all the paint on my 60 falcon I have some bleed thru my primer in spots I did not touch . Will I have to sand down and remove what ever is under this primer to fix this problem?
cohammer60 is offline   Reply With Quote
Old 05-14-2014, 01:06 AM   #2
s55mercury66
s55mercury66's Avatar
Default Re: Body work
Yes, you will have to sand that down and make sure it is clean before you re-prime. Use a quality degreaser, that is made for automotive refinishing, before priming. What is your primer?
Looking for bucket seats and rocker mouldings for full-size 1966 Mercury.
s55mercury66 is offline   Reply With Quote
Old 05-14-2014, 07:53 AM   #3
1967gt
1967gt's Avatar
I can tell you what primer it is, inferior, means you are going to have to spend some $$ on better products, maybe a direct to metal primer (dtm) also,, not all primers are meant to go on bare metal,,,
1967gt is offline   Reply With Quote
Old 05-14-2014, 11:07 AM   #4
cohammer60
cohammer60's Avatar
Thanks for the info. I am going to take it to a local body shop to have it painted but I think I will resand it and make sure there is no issues before I take it. I think I may have used the last of some old primer in that spot hope that's all that's wrong. It has been about a year so that looks like the only spot.
Old 05-14-2014, 04:02 PM   #5
frank long island
frank long island's Avatar
did you use stripper to remove the old paint you have to strip the entire panel back to bare metal and degrease /clean with a good prepsol and reprime as asked before what type of primer did you use some of the new finishes do not like lacquer primers of yesteryear you should go with a 2k primer surfacer
frank long island is offline   Reply With Quote
Old 05-14-2014, 04:45 PM   #6
cohammer60
cohammer60's Avatar
No that is the problem I guess , I did not get it clean enough and sprayed over some old primer and did not get all the way to bare metal.
Old 05-17-2014, 10:19 AM   #7
Ralph Moore
Ralph Moore's Avatar
I had similar issues using enamel paint , when I put the first coat it was ok, but second coat made it bleed through, paint shop said instead of stripping it all back off that I could use a good epoxy primer and seal it , then repaint.
Although I have not tried it yet.
Ralph Moore is offline   Reply With Quote
Old 05-17-2014, 02:50 PM   #8
mikhett
strip to bare metal clean with wax n grease remover epoxy prime . DONE!
mikhett is offline   Reply With Quote
