Old 08-12-2012, 10:53 PM   #1
redbeard
redbeard's Avatar
Default 10 spline coupler source?
Hello,
The coupler on my 33 drive line is so worn out it moves 3/8" at the transmission end of the shaft. And that is with the pin still in place.
Needless to say I am trying to find a good coupler to replace it with, and since it gets welded to the drive shaft, I don't want to put on another
used up one.
I have used the after market ones in the past on my 41 rear end, and they wore out extremely fast. It seem to wear out faster than the original ford one.
I ended up finding a good original one for that rear end and never had a problem again.
So are there any suppliers out there that have a good coupler for the 10 spline pinion?
I heard that the Early Ford store was working on having them made, but I don't see it in their catalog.
Thanks
Dave
redbeard is offline   Reply With Quote
Old 08-12-2012, 10:59 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 10 spline coupler source?
Try Dick Spadaro in NY.
Old 08-13-2012, 05:44 AM   #3
PeteVS
PeteVS's Avatar
People cut the ends out of '33-'34 drive shafts to weld in the couplers to get a six spline configuration. I'll look to see if I have one somewhere. (I should have one.)
If your coupler is worn, what does the spline on the pinion look like??
Old 08-13-2012, 09:23 AM   #4
redbeard
redbeard's Avatar
The pinion is not as worn as some of the other ones I have around here.
Plus it is a factory 3.54 ring and pinion, so I am going to make the best of it.
I would like to start with the best coupler I can and see how that
fits the pinion.
Thanks for your help.
David
Old 08-13-2012, 08:51 PM   #5
redbeard
redbeard's Avatar
tried Dick Spadaro,
no luck there. they said they are no longer selling the drive shafts,
and they don't have any 10 spline bungs or couplers.
thanks
Dave
Old 08-13-2012, 09:09 PM   #6
nospartsman
Try Early Ford Store San Dimas, Ca 909-305-1955 or All Ford Parts Campbell, Ca 800-532-1932
nospartsman is offline   Reply With Quote
Old 08-14-2012, 12:10 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
I have the splined ends that I removed from several '35-'36 tubular drive shafts that were made into lake pipe exhausts. The bungs removed from the pinion ends of these shafts have good internal splines that will fit a 10 spline pinion. One of these may work perfectly for what you are trying to accomplish.
John
Old 08-14-2012, 09:34 AM   #8
redbeard
redbeard's Avatar
Yes, that would work perfect.
Are you willing to sell one?
Thanks
Dave
Old 08-14-2012, 10:51 AM   #9
JM 35 Sedan
Yes, all have good internal splines. I will send you a picture when i get back home from Bonneville on Thursday.
John
Old 08-15-2012, 09:11 AM   #10
redbeard
redbeard's Avatar
Great, I really appreciate it.
Old 08-19-2012, 09:56 AM   #11
DICK SPADARO
This is for any people still following this thread and for information about drive shaft and coupler problems. It is important to note that if you are experiencing an issue with the drive line on your car such as excessive coupler wear or the shearing of the coupler pin it is a sign that there is a problem with the alignment of your drive shaft. The driveshaft operates on a central axis thru the end of the transmission and the pinion snout. If these ends are not in the same alignment it creates a deflection in the drive shaft causing it to bow as it spins and the faster the spinning the more deflection. If you have a non stock drive shaft there are two issues that you must check to determine if the drive shaft runs true.
First is to determine that the pinion coupler is installed on center and square to the drive shaft u-joint spline.
Second is to determine that the torque tube section is also married together on center and that the torque tube flanges are square and parallel at each end.
The same observation is true for a stock torque tube, if you are experiencing sheared coupler rivets or excessive slop in the coupler it is a good sign that the vehicle was in an accident and the torque tube was bent. This is difficult to determine by eye but the coupler problem indicates that the shaft is not running true. The wear damage is caused by the force of drive shaft created as it attempts to spin on a central axis.
If you have any of these issues it requires further examination as replacing a coupler is not necessarily the problem.
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 08-19-2012, 10:20 AM   #12
Andy
I need to shorten a 34 set to use in my 32. I will check the driveshaft alignment by putting the shaft on the pinon and spinning it. I hope it turns true and doesn't wobble on the trans. end. I plan to shorten the torque tube near the trans end. I will put the driveshaft in it and move the rear end end from side to side. Hopefully the movement will be centered. The front bearing is probably not tight enough for this but at least I can check if one direction is tight.
Andy is offline   Reply With Quote
Old 08-19-2012, 10:06 PM   #13
redbeard
redbeard's Avatar
Mr. Spadaro is absolutely correct.
Apron further inspection I discovered that my torque tube was bent
It did indeed put a bend it the drive shaft while rotating.
Luckily our local driveline shop was able to straighten it out and I am
now back on the road.
Thank you for the help.
And thanks Mr. Spadaro for explaining the details to help others on here
There is not a good source for these couplers folks so be aware of that
and hold on to the pieces if you are shortening a shaft or changing to 6 spline.
Cheers
