Old 02-07-2021, 01:53 PM   #1
tinman7
tinman7's Avatar
Default Tires
What width tire should I buy for my 1930 town car they are 19". I have 4.75x19 on it now, any thoughts?
tinman7 is offline   Reply With Quote
Old 02-07-2021, 02:02 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Tires
You have the correct size.
Old 02-07-2021, 04:00 PM   #3
nkaminar
nkaminar's Avatar
Default Re: Tires
I understand the the Firestone 4.75 x 19 tires are a little larger than the others.
Old 02-07-2021, 07:25 PM   #4
McMimmcs
McMimmcs's Avatar
Default Re: Tires
That’s is the correct size so why change ? Keep your car as original as possible.
Old 02-07-2021, 07:42 PM   #5
J Franklin
J Franklin's Avatar
Default Re: Tires
Maybe slightly larger profile, still correct for the car. if you have side mounted spares they are snug in the well. I like the look of the Goodyear tires, The Montgomery Ward tires had the best tread design in my opinion, it was being reproduced for some size of tire, T I think. Sears zig-zag tread was period correct. It was found on an economy tire. Similar with the Insa Premier, these were treads used by major tire manufactures like Goodyear and Firestone.
Old 02-08-2021, 05:34 PM   #6
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Default Re: Tires
If you are buying a whole set, I would spend the money and get radial tires.
Just my opinion.
fried okra is offline   Reply With Quote
Old 02-08-2021, 06:03 PM   #7
McMimmcs
McMimmcs's Avatar
Default Re: Tires
Just my opinion.
If you’re not going to tour I wouldn’t invest in the radial tires. It is a significant expense and you immediately give your A a hot rod appearance. Others may well disagree !
Old 02-09-2021, 04:36 AM   #8
old31
Default Re: Tires
I have radials on my 19" and you can not tell they are radials.
I agree with Fried. If you are going to be buying a set of new tires you would be foolish not to get radials. The ride difference is much better.
I guess if you are a point car you might have to stay with biased.
old31 is offline   Reply With Quote
Old 02-09-2021, 03:29 PM   #9
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
Default Re: Tires
I have worn out 2 sets of Firestone tires. My latest buy was Goodyear tires. I like Goodyear tires much better than Firestone tires as they hold the road better and your A will have reduced wandering. In other words, they take you straight down the road.. A little more expensive than Firestones but worth it.
Dick M is offline   Reply With Quote
Old 02-09-2021, 03:50 PM   #10
JayJay
Default Re: Tires
Originally Posted by J Franklin View Post
Maybe slightly larger profile, still correct for the car. if you have side mounted spares they are snug in the well. ...
A bit more than "snug". The previous owner of my pickup (left fender well) put Firestone on it. When inflated I can't push the tire down into the well, and if I deflate, insert and then inflate I can't move it out. So I carry it deflated and have a 12V air compressor and a power brick to inflate if I need it. My suggestion to anyone who has a fender-well spare is don't even consider Firestone.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 02-09-2021, 06:54 PM   #11
CarlG
CarlG's Avatar
Default Re: Tires
My 550R19 radials fit the fender well better than the 475x19 Firestones did. Ride a whole bunch better as well.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-09-2021, 08:00 PM   #12
nkaminar
nkaminar's Avatar
Default Re: Tires
For those with radial ties, how would you describe the ride, other than better. Does it track better, less wondering, smoother ride, better handling?
Old 02-09-2021, 08:37 PM   #13
Jacksonlll
Jacksonlll's Avatar
Default Re: Tires
With a town sedan, I know what you don’t want. I had the low cost tires from Vietnam and the yaw was so severe, I could hardly drive it. With a little steering input, my quail moved left and right3 or 4 inches each way. Very bad. I put Firestones on and that fixed it.
Old 02-10-2021, 09:24 AM   #14
old31
Default Re: Tires
Yes, it tracks better, less wondering, smoother ride, better handling on corners.
Old 02-10-2021, 09:49 AM   #15
Brewsterbuff
Brewsterbuff's Avatar
Default Re: Tires
WOW! A 1930 Town Car. RARE BIRD! I prefer to keep them original. A Model A was never meant to drive and ride like an Eldorado.
Brewsterbuff is offline   Reply With Quote
Old 02-10-2021, 10:06 AM   #16
Boston Bruce
Boston Bruce's Avatar
Default Re: Tires
Here is my '31 sedan with radials. Hot rod??? What?
Boston Bruce is offline   Reply With Quote
Old 02-10-2021, 07:27 PM   #17
Stingray70
Stingray70's Avatar
Default Re: Tires
That is a very nice looking car Boston Bruce.
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 02-10-2021, 09:44 PM   #18
Big hammer
Default Re: Tires
Your radials don't look like radials ! What brand, size are they, I'am going to put radials on soon ! My late 31 Tudor sways in the wind and body rolls turning corners.
get a bigger hammer tap done
Old 02-10-2021, 09:55 PM   #19
Doug Linden
Doug Linden's Avatar
Default Re: Tires
A friend has 5.00/5.50 x 19 Lester Tires on his Town Sedan and likes the ride and looks of them.
Doug Linden is offline   Reply With Quote
Old 02-11-2021, 06:43 AM   #20
nkaminar
nkaminar's Avatar
Default Re: Tires
Here are the radial whitewalls.
https://www.cokertire.com/tires/amer...19-700325.html
I believe they have blackwalls too.
