10-08-2015, 10:17 AM | #1 |
How do you delete a post
How do you delete a post, I messed up.
Thanks Herm. |
10-08-2015, 10:43 AM | #2 |
Re: How do you delete a post
Herm, click the EDIT button, then the DELETE button will appear, it's quite easy. I've deleted a LOT of DUMB posts.
Bill W.
10-08-2015, 10:45 AM | #3 | |
It was one of my posts that I have the wrong pictures on. If I list a political comment, Ryan might delete me! Thanks Mr. Coupe, Herm. |
10-08-2015, 10:57 AM | #4 | |
Thanks, Bill, Herm. Last edited by Kohnke Rebabbitting; 10-08-2015 at 12:55 PM. |
10-08-2015, 10:59 AM | #5 |
Herm,
Click on report (below your avatar) and write a note to Ryan or Cob and they will delete it. If the post is the first one on a thread AND someone has responded to it I do not think you are allowed to delete ... but report works in all situations. If your post is in response to a thread I think you can delete in most situations. Last edited by Benson; 10-08-2015 at 11:30 AM. |
10-08-2015, 11:07 AM | #6 |
10-08-2015, 12:52 PM | #7 |
I will try that, the post I was going to delete, I listed the wrong pictures. I found out if I went to list more pictures, and deleted the wrong ones, the I listed the right ones, it all camw out right.
Thank you to all, and Mr. Red I will try that with this post to see. Thanks, Herm. |
10-08-2015, 01:01 PM | #8 | |
There is two little boxes, one says "do not delete" the other says "delete" Look for the boxes and click, took me twice to figure that out.
