Old 10-08-2015, 10:17 AM   #1
Kohnke Rebabbitting
Default How do you delete a post
How do you delete a post, I messed up.
Thanks
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 10-08-2015, 10:43 AM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: How do you delete a post
Herm, click the EDIT button, then the DELETE button will appear, it's quite easy. I've deleted a LOT of DUMB posts.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-08-2015, 10:45 AM   #3
Kohnke Rebabbitting
Originally Posted by 1930 coupe View Post
If it is a response to another post, click edit then you will find a delete button.
If it is a post that you started, the only way is to make some political commits then Ryan will delete it for you.
You can always click EDIT and correct your post.
It was one of my posts that I have the wrong pictures on.
If I list a political comment, Ryan might delete me!
Thanks Mr. Coupe,
Herm.
Old 10-08-2015, 10:57 AM   #4
Kohnke Rebabbitting
Bill W.
Thats what I thought also, but there is not a delete button to be found.
Thanks, Bill,
Herm.
Old 10-08-2015, 10:59 AM   #5
Benson
Benson's Avatar
Herm,
Click on report (below your avatar) and write a note to Ryan or Cob and they will delete it.
If the post is the first one on a thread AND someone has responded to it I do not think you are allowed to delete ... but report works in all situations.
If your post is in response to a thread I think you can delete in most situations.
Old 10-08-2015, 11:07 AM   #6
redmodelt
redmodelt's Avatar
If it's your post you will see the edit button, click it and will open to make changes. Then click the Go advanced button. The box to delete message will open. The delete box in the first window only removes changes you made in the edit (I think)
Old 10-08-2015, 12:52 PM   #7
Kohnke Rebabbitting
I will try that, the post I was going to delete, I listed the wrong pictures. I found out if I went to list more pictures, and deleted the wrong ones, the I listed the right ones, it all camw out right.
Thank you to all, and Mr. Red I will try that with this post to see.
Thanks,
Herm.
Old 10-08-2015, 01:01 PM   #8
burner31
burner31's Avatar
Bill W.
Just did it, it works, just one thing.
There is two little boxes, one says "do not delete" the other says "delete"
Look for the boxes and click, took me twice to figure that out.
Keith
Shawnee OK
'31 SW 160-B
