01-26-2018, 12:10 PM | #1 |
Slang-feel free to add
A-Bomb: any Model A Ford that has been extensively modified.
A-Bone: slang for the Model A Ford, which was produced between 1928 and 1931. Alky: alcohol fuel used for racing, including methanol or methyl alcohol. Antique: by most club standards, any vehicle that is at least 25 years old. Appletons: fender-mounted spotlights, named for the manufacturer. Baby HEMI: any early HEMI engine, which was produced by Chrysler’s Dodge and DeSoto divisions and had smaller dimensions and displacement than Chrysler’s other HEMI offerings. Baby Moons: small, chromed hubcaps that only cover the center of the wheel. Backhalf: to reconfigure any stock vehicle’s rear components (narrowing the rear-end, adding wheel tubs, etc.) typically for better drag racing performance. Bagged: having a custom airbag suspension system. Balanced: normally used to define balancing the rotating mass (crankshaft), but could also could refer to matching the weights of the pistons and rods. Baloneys: automotive tires, especially large rear tires used on hot rods or drag racing vehicles. Banger: a slang term used to express the number of cylinders in an engine (four-banger = four-cylinder, etc.). Banjo: an early style rear-end that resembles the shape of a banjo. Barn Find: any vehicle that was stored away in a barn or similar structure for an extensive period of time and then found and restored. Basket Case: any vehicle that was completely disassembled–or needs to be completely disassembled for restoration or modification purposes. (Referred to as basket case because the process often involves gathering and collecting small parts in a basket over a long period of time). Beach Wagon: a term for a station wagon used mostly in New England Beam Axle: any automotive front axle featuring the cross-sectional shape of an I-beam. Belly Pan: sheetmetal body panel, which has been custom fabricated to tightly conform the underside of a racing vehicle. Beltline: the line running around a car’s body formed by the bottom edges of the side windows. Big ‘n Littles: a hot rod or dragster tire combination which employs large rear tires for traction and small front tires for reduced rolling resistance. Binders: brakes. Blower: a supercharger. Blown Gasser: a supercharged, gas-burning engine. Blueprinting: the act of ensuring the dimensions of the parts in the engine are more accurate and, therefore, closer to the original engine blueprint values. Boattial: a speedster with a tapering (V-shaped) rear section. Bobbed: shortened, as in bobbed fenders or frame rails. Bonnet: the hood over the front engine. Brougham: an early motoring term signifying a closed car for two or four persons. Bullets: chromed, bullet-shaped extensions used on bumpers, grilles, and wheels. Bumpstick: slang for camshaft. ford-de-luxe-business-coupe-03 Business Coupe: Ford Deluxe Business Coupe Business Coupe: a simple two-door coupe, without a rumble seat, built in the mid- to late-thirties. (Also referred to as a Businessman’s Coupe). Cabriolet: a convertible with windows. California Top: a fixed rigid top applied to a touring car, replacing the regular folding top. Carson Top: a solid, removable roof that is covered with a soft material. Channeled: cutting the floor so the body rests around the frame rails rather than sitting on top of the frame. This gives an overall lowered appearance. Chopped: a hard-top car that has had its roof lowered. Classic: a fine or unusual motorcar typically built between 1925 and 1948, often distinguished by its fine design, high engineering standards, and superior workmanship. Club Coupe: a two-door closed car with rear seat. Coach: a two-door sedan. Convertible: an open-top car with a folding roof and side windows. Coupe: a closed car with two doors. Crate Engine: a factory-built, ready to run engine. Custom: a car that is modified in visual appearance through imaginative and technical methods to create a distinctive vehicle. Cycle Fenders: usually a front and sometimes rear fender similar to that used on a bicycle, which follows the curvature of the wheel. D-L Dago: a dropped front-end. Decked: chrome details and trim removed from the trunk and smoothed over. Deuce: 1932 Ford. Digger: drag racing slang for dragster. Donor Car: a vehicle used to provide parts and hardware for another project vehicle. Dropped: a significantly lowered vehicle. Dual Quad: two four-barrel carburetors. Dutchman Panel: the metal body piece between the rear window and the trunk. Duvall Windshield Duvall Windshield Duval Windshield: a split V-shaped raked chrome-plated windshield designed by George DuVall Exotic: a high-priced, two passenger roadster, coupe, or convertible, usually from Europe (a few exceptions exist such as the Shelby Cobra). Fade-Aways: fenders that taper back into the body. Fat Fendered: Fords built between 1935 and 1948 that were wide and rounded in appearance. Fender Skirts: body panels that cover the rear wheelwells. Filled Roof: a roof that has a welded steel panel instead of the original wood-and-fabric insert. Flamethrowers: tailpipes that shoot flames (unburnt gas). Flathead: an L-head or side-valve engine, including the highly popular Ford Flathead built between 1932 and 1953. Flopper: drag racing slang for a Funny Car. Fordor: a four-door Ford sedan. Frame-off Restoration: a restoration project in which the entire vehicle is completely disassembled with all parts cleaned or replaced as necessary, so that the restored car meets the original factory specifications as closely as possible. Frame-Up Restoration: not as detailed as a frame-off restoration, this process involves restoring the paint, chrome, interior, and mechanicals to original specifications without complete disassembly of the car. Frenched Frenched Taillights Frenched: recessed head or tail lights that are smoothed into the body panels. Front Clip: either the front-end sheetmetal or the section of frame in front of the firewall. Glasspacks: loud aftermarket mufflers, which typically use a straight-through perforated tube wrapped in fiberglass. Goat: Pontiac GTO. Hair Dryer: slang for turbocharger Headers: fine-tuned exhaust manifold that is more efficient than stock. HEMI: an engine popularized by Chrysler that has hemispherical combustion chambers in its cylinder head. Highboy: a fenderless customized Model A Ford coupe or roadster that sits at stock height. Hot Licks: flames painted on the side of a car. Hot Rod: traditionally, an older vehicle with “low-buck” performance modifications. Kit Car: a reproduction of an existing automotive design, sold in various stages of production to allow for completion and customization by the builder. Lakepipes: side-exit exhaust pipes located under the rocker panels. Land Yacht: a large, luxury car, usually referring to the chromed, finned, oversized vehicles of the late fifties to early sixties. Laughing Gas: slang for nitrous. Leadsled: a lowered, late-forties car with molded body seams, traditionally done with lead. Louvers: vents or slots punched in body panels. Lowboy: customized Model A Ford that has been channeled. Lowered: a vehicle that sits lower than stock height through suspension or frame modifications. Lowrider: a vehicle that has been lowered by a hydraulic suspension system that can bring the ride height up in order to drive it. M-R Mags or Mag Wheels: race-inspired aftermarket wheels; referred to as mags because early style race wheels were made from magnesium. Matching Numbers: a restored or original vehicle in which all serial numbers (VIN, engine, body, transmission, rear end) can be researched and identified as being 100 percent correct for that specific vehicle. Mill: slang for an internal combustion engine. Molded: body seams that have been filled in or otherwise smoothed out. Moons: full wheel covers that are chrome and convex-shaped. Mother-in-Law Seat: a single seat attached to the back of a two-seater car. The forerunner of the rumble seat. Mouse: slang for small block Chevrolet engine. Muscle Car: a North American intermediate or mid-sized car produced between 1964 and 1972 (with a few exceptions) with a large displacement V8 engine. Nailhead Buick Nailhead Engine Nail Head: 1950s Buick engine Nerf Bar: tubular bumper or step bar. NOS: (New Old Stock) parts purchased from the manufacturer that were made at the time of the original vehicle but never sold. (Also an abbreviation for Nitrous Oxide System). Nosed: chrome details and trim removed from the hood and smoothed over. Original: contains only parts originally installed on the car or NOS parts from the manufacturer with no substitute or aftermarket parts. Pancaked: hood modified to a lower profile. Peaked: a molded accent seam on a hood. Pinched: to narrow the front frame to match the grill shell. Pink Slip: before the days of automobile titles, the portion of a California car registration that conveyed ownership was colored pink. Piped: narrow, padded pleats used to trim the interior. Pony Car: a small, compact performance-oriented vehicle. Ported: to polish and enlarge the intake and exhaust ports on cylinder heads. Post: the pillar located between the front and rear doors of a four-door sedan. Powerplant: slang for an internal combustion engine. Project Car: a vehicle that is in restorable condition. Pro Street Pro Street-style Mustang Pro-Street: a street/strip-style vehicle that features large rear wheels and tires tucked deeply into the rear fender area. Puke Can: a radiator overflow tank used to catch coolant. Quarter Window: the side window behind the rear door. Rake: the downward angle of a car with a dropped front suspension. Raked: a design in which the front end has been lowered more than the back. Rat: slang for big block Chevrolet engine. Rat Rod: a style of hot rod that imitates the early rods of the 1940s-60’s, featuring an unfinished, rough, or patina appearance. Replicar: a completed reproduction of an existing automotive design, usually sold only 100 percent complete car. Resto Rod: an original looking car with a modified chassis or powerplant. Restored: to return a car to its original showroom condition. Roadster: a convertible without side windows. Roll Pan: smoothed out panel that replaces the bumper and rolls back under the vehicle. Rolled: bumper or gas tank removed and replaced with custom panel that “rolls” under. Rolled & Pleated: deluxe interior sewn with padded pleats. Rumble Seat: an open, fold-up rear seat located where the trunk would be. Running Board: the metal strip running between the fenders and below the doors of early autos and trucks used as a step or to wipe one’s feet before entering the vehicle. S-Z Sectioned: removing a horizontal section of bodywork to lower the overall height of the body. Sedan Delivery Sedan Delivery Sedan Delivery: a two-door station wagon with solid body panels instead of windows on the sides at the back of the car. Shaved: door handles and body trim that have been removed and smoothed over. Shoebox: nickname for 1955-57 Chevrolet cars and 1949-51 Ford cars. Sidemount: a spare tire recessed into the front fender. Six-Pack: three two-barrel carburetors. Slammed: a significantly lowered vehicle, usually dropped as low as possible and still driveable. Sleeper: a vehicle that doesn’t look as fast as it is. Slingshot: a front-engine dragster. Slushbox: an automatic transmission. Split Window: usually referring to the rear window, this window has two planes of glass with bodywork in between. Spyder: a light two-seat roadster. Steelies: solid, stamped-steel wheels. Stovebolt Stovebolt Chevrolet Engine Stovebolt: a hot rod running a Chevrolet straight inline six-cylinder engine, which had cylinder head bolts similar to those on wood burning stoves. Strangler: slang for a carburetor choke. Street Machine: a street-legal highly modified car or truck built in 1949 or later. Street Rod: a street-legal highly modified car or truck built in 1948 or earlier. Stretched: a vehicle with a body that has been stretched to lengthen the overall size of the vehicle or to accommodate larger tires. Stroked: an engine which has been modified with a longer piston stroke thereby increasing displacement. Suede: primer Suicide Door: a door that hinges at the rear. Supercharger: a crank driven air-to-fuel mixture compressor which increases atmospheric pressure on the engine, resulting in added horsepower. Survivor: an original, unrestored, unmolested antique car that is in good enough condition to be used as a model for the restoration of a similar car. T-Bucket: fenderless, topless, highly-modified Ford Model T. Teardrops: 1939 Ford taillights, which have become very popular on custom hot rods. Trailer Queen: derogatory term referring to a car that is shown frequently yet rarely driven. Tri-Five: nickname for 1955-57 Chevrolets Tri-Power A Tri-Power Induction Setup Tri-Power: an engine with three two barrel carburetors. Tubbed: having the rear frame and body modified to allow for extra-wide wheels and tires that do not protrude past the fenders. Tudor: a two-door Ford sedan. Turnkey: a completely finished hot rod built by a professional shop and requiring no additional work. VIN Vehicle Identification Number: the vehicle serial number that is stamped onto the vehicle, usually under the windshield post, the driver’s door post, or on the firewall. Vintage: a vehicle built between 1915 and 1942 in stock or unmodified condition. Wheelie Bars: rods that extend from the back of a car and are connected to wheels that help keep the car from flipping backwards during sudden acceleration. Zoomies Zoomies, or Zoomy Headers Whitewalls: tires that have a concentric white line. Woody: a vehicle that incorporates natural finished wood for structure of exposed body panels. Zoomies: open headers that exit at the side of a vehicle and are pointed upward. by David Fuller
01-26-2018, 12:29 PM | #2 |
Re: Slang-feel free to add
Did you make all that up???
Marshall |
01-26-2018, 01:33 PM | #3 |
Nope
Gave credit to "by David Fuller" at the bottom of the post
01-26-2018, 01:34 PM | #4 |
Towering inferno: holly T-pot carb..
Alive n kickin n mostly kickin! |
01-26-2018, 02:37 PM | #5 |
Cherry Bombs: glass pack mufflers painted red.
David Serrano |
01-26-2018, 03:22 PM | #6 |
01-26-2018, 03:28 PM | #7 |
Smitty's Straight thru muffler packed with steel shavings. Marvelous rap/rumble sound, makes a dual exhaust Chev 6 the best sound around.
01-26-2018, 04:01 PM | #8 |
Bolt action - 3 on the tree shifter
01-26-2018, 04:18 PM | #9 |
NEVER heard '55 to '57 Chevs called SHOEBOXES!
Last item, they're not Zoomies, they're called CUT-OUTS! Syncro, a device for UNTRAINED ROOKIE Shifters, like, if you can't shift the danged thing, DON'T DRIVE IT, DUFUS!!! There's No word for Radiator Fans, those are jist for Old Folks in their Ramblers! Didn't mention "MAD MONEY"---That's what the Girl has stashed, in case her Boyfriend dumps her out of the car. She should, instead, carry a HAMMER, in her PURSE! Or a pistol, with BLANKS, he'd DIE of FRIGHT! Just point it in his CROTCH & go BANG!--LOL---"Maybe" there's a market for BULLET PROOF Undies???---What's better than Hot Rods, Sex & '50s Rock & Roll Music? (NOTHING!) Bill Rascallion
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 01-26-2018 at 04:30 PM. |
01-26-2018, 11:27 PM | #10 |
Oh Boy! Here we go with more obviously false information presented as fact! Look at the "Stovebolt" definition. A Chevy inline six DID NOT have "head bolts similar to bolts on a wood burning stove"! Where did that come from?? (From ignorance, I think.) A stovebolt has a flat top head with a screwdriver slot, and the underside of the head tapers down to the shank diameter. Wouldn't work very well as a head bolt! Go to fastenermart.com and type in slotted flat head stove bolts for a drawing.
01-26-2018, 11:52 PM | #11 |
CUTOUT SWITCH Permitted exhaust through either the muffler or to straight pipes
DEUCE Two BBL Carb as in triple Deuces or 3 Deuces GEORGE OVERDRIVE Turning off the engine on hills Last edited by Bruce Adams; 01-26-2018 at 11:57 PM. |
01-27-2018, 12:00 AM | #12 |
I liked the read,thanks.
01-27-2018, 08:30 AM | #13 | |
01-27-2018, 10:50 AM | #14 |
Deuce = '32 Ford
Sliptivity fluid = oil Six pack = 6 cylinder in-line engine Musical transmission = manual transmission w/spur cut gears that whines in first and second gears.
01-27-2018, 11:04 AM | #15 |
01-27-2018, 11:32 AM | #16 |
"stovebolts" can be slotted flat countersunk or slotted pan head. I don't know why the chevy inline 6 was/is called a "stovebolt", only that it was/is. If the valve cover, side cover and pan came with slotted pan heads then that would seem a reasonable reason for the nickname. The one in my '57 truck has pan head philips for the valve cover (obviously been changed) and regular 1/4" hex bolts on the side cover (also possibly changed). I wasn't interested enough to climb under and check the pan bolts but I suspect, 1/4" hex.
01-27-2018, 11:57 AM | #17 |
I don't consider myself a Motorhead but I recognize a high percenage of those. That's scary.
01-28-2018, 12:09 AM | #18 |
Thank you, that list brought back a bunch of memories. I do have a few to add:
Drag pipes: long chromed exhaust pipes that ran along the bottom edge of each side of the car and were illegal unless capped. Cut-outs: cables hooked from dash to where drag pipes connected to regular exhaust and controlled a valve that opened and closed drags pipes when the caps were off the drag pipes Lakers: same as drag pipes Spinner or squirrel knob: attached to steering wheel and made turning the wheel much easier. Very dangerous and often got caught in shirts or jackets Full moons: spun aluminum wheel covers that covered the entire metal rim and cut down on wind resistance Leaded; before Bondo and body filler, holes and seams were filled with moltan lead which quickly hardened and was shaped to smooth out the body and fenders Roll bar or bars: installed behind front seat on open cars for protection if car rolled Ported and relieved: engine exhaust ports are enlarged and polished by using a wire brush on a drill. Same is done to intake ports on manifold or headers Some of this stuff originated in Southern California and worked its way up the West Coast, so it wasn’t necessarily used elsewhere. Mike |
01-28-2018, 07:55 AM | #19 |
MUD ...the car has alot of Mud in it ,reffering to bondo or other body filler.
01-28-2018, 09:12 AM | #20 |
Muffler clutch: What you send the new kid in shop class to look for or ask the shop teacher.
