Old 08-18-2020, 10:29 AM   #1
carguybill
carguybill's Avatar
Default Stiff steering
I haven't driven my '34 for over a year but when I did today the steering was very stiff. It's never been good but this is worse(or maybe It's because I'm a year older). The steering box has been filled with John Deere corn-head grease (or some name like that).
When i last worked on the car I was working on the brake system.
Any ideas or suggestions?
carguybill is offline   Reply With Quote
Old 08-18-2020, 11:05 AM   #2
cas3
Default Re: Stiff steering
jack up the front end and grease the king pins. crank the steering wheel back and fourth lock to lock, then grease them again. while its up grab the top and bottom of a wheel and try and wiggle it to see if the king pin bushings, and or pins are shot.
Old 08-18-2020, 11:06 AM   #3
Floyd
If the steering system is all stock, then the first culprit would be the rubber bushing up at the top of the column. When old, they become more of brake than a bushing. The only non-stock steering item I recommend is the bearing system that is made by the guy in MN or WI. (Bushard?) It is superior to any thing else like the cheap ones or the later pickups. I have them on my '40 and my '32. Very easy steering. Get the good one.
No, being one year older has no effect. Multiply that by some large number and then, maybe so.
Floyd is offline   Reply With Quote
Old 08-18-2020, 12:08 PM   #4
drolston
drolston's Avatar
The design of pre '37 steering boxes is notorious for getting stiff. Many replaced them with later type steering boxes.
Old 08-18-2020, 01:02 PM   #5
carguybill
carguybill's Avatar
thanks Guys, Ill look into these suggestions.
Old 08-18-2020, 10:58 PM   #6
Lanny
Lanny's Avatar
Do you run radial tires or bias tires ?
Radial tires steer a little harder than bias tires at slow speed.
Also make sure the air pressure is up to par in the front tires
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 08-21-2020, 09:40 AM   #7
carguybill
carguybill's Avatar
I am not familiar with the guy in MN or WI that has the bearing system that you mention. can anyone give me a lead?
Old 08-21-2020, 09:47 AM   #8
Kens 36
Kens 36's Avatar
Bill,
Dans contact information is
Dan Brusegard
Maple Grove, MN
763-533-9879
[email protected]
The bearing he sells is very well made, comes with great instructions, and worth every penny. I put one in my '36 and am very happy I did.
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 08-21-2020, 02:08 PM   #9
RKS.PA
RKS.PA's Avatar
Originally Posted by Kens 36 View Post
Bill,
Dan Brusegard
Maple Grove, MN
763-533-9879
[email protected]
Ken
2X on the replacement kit. Put it in my '39. Worth every penny and excellent installation instructions!!
RKS.PA is online now   Reply With Quote
Old 08-28-2020, 04:33 PM   #10
carguybill
carguybill's Avatar
Bill,
Dan Brusegard
Maple Grove, MN
763-533-9879
[email protected]
Ken
Thank you. I have asked him for more information.
