Old 02-29-2024, 11:40 AM   #21
TJ
TJ's Avatar
Default Re: Can’t get brake lights to work (new wiring)
Originally Posted by pistonbroke View Post
TJ, Not to be rude but having wired many cars and trucks over the years I have to disagree. The brake light power goes to the brake light switch and on to turn signal switch where it may or may not go to both tail lights depending on the position of the turn switch. There is power to the tur switch but it is for the turn signal function only. That's why your brake lights work anytime you apply the brakes but your turns only work when the key or ignition switch in this case is on. Again no disrespect , Tim
You are correct. No problem on catching my mistake. If I was right all the time I would have made more money!
