08-23-2014, 09:28 AM | #21 |
Re: Four barrel
Joe, Be aware that the OFFY 4 bbl. manifold has the generator mounting flange offset 7/8 inches towards the driver side of car. Because of this the 8BA crank pulley and fan pulley will not line up vertically. Use an EDELBROCK intake.
08-23-2014, 09:37 AM | #22 | |
Re: Four barrel
Just ask the 100's who are using an Offy manifold and don't even realize that it is offset.
08-23-2014, 10:08 AM | #23 |
Re: Four barrel
Plus, the generator will also be "offset" and may not be pleasing to some folks.
08-23-2014, 10:31 AM | #24 |
Re: Four barrel
To 'please' myself when I discovered that I was going to have fan shroud interference I fabricated a 7/8" offset fan hub mount to put the fan on center
08-23-2014, 10:34 AM | #25 |
Re: Four barrel
08-23-2014, 10:41 AM | #26 |
Re: Four barrel
08-23-2014, 11:59 AM | #27 |
Re: Four barrel
40cpe, same carb, 1404 is new 9904 is rebuilt by Edelbrock, I should've just said 1404. Just had the 9904 on the brain from when I purchased.
Nomad |
08-23-2014, 01:47 PM | #28 |
Re: Four barrel
Hmmm,
'52 Olds Rochester 4 barrel........all mechanical, no vac flapper secondaries. Tune it w/ A f meter. Big plus, it looks and is vintage. I've got a bunch of them out there. Charlie ny |
08-23-2014, 02:07 PM | #29 |
Re: Four barrel
08-23-2014, 03:23 PM | #30 |
Re: Four barrel
I got a edelbrock manifold and a 52 olds wcfb these manifolds were made for early carters and rochesters,the olds has the linkage on the pass side to boot,its ready to go on my 41 w/50 merc engine,has offy heads isky cam reds headers and smittys..oldskool
08-23-2014, 03:32 PM | #31 |
Re: Four barrel
What about the slant you have as a result of the manifold being for a 49-53? I would think that would pose a problem installed in a 41 where the top of the manifold was level. I have one of those and have thought about having a wedge machined to make the carb set level.
08-23-2014, 03:50 PM | #32 |
Re: Four barrel
I asked a question the other day 're 8BA manifolds on an early engine in an early car ( flat level engine) answered by Ol Ron and Walt, be done loads of times, not a problem worry ye not, type of thing. Pay it no mind.
Martin. |
08-23-2014, 03:56 PM | #33 | |
Re: Four barrel
Many thanks. Martin. |
08-23-2014, 04:00 PM | #34 | |
Re: Four barrel
08-23-2014, 04:29 PM | #35 | |
Re: Four barrel
It took about twenty minutes to setup & mill. Now it looks right. |
08-23-2014, 05:43 PM | #36 |
Re: Four barrel
How about these, Charlie?
08-23-2014, 06:35 PM | #37 |
Re: Four barrel
I plan on using the alternator that I am using now .It looks like the same bracket should work.Thanks for all the info guys ,appreciate it
08-23-2014, 06:52 PM | #38 |
Re: Four barrel
Kahuna,
I er a well geez........that is...........I love it. Did you fab the intake ? Please let us us all know how it runs....it'll be awesome !! Plus it's difernt. Charlie ny |
08-23-2014, 09:31 PM | #39 |
Re: Four barrel
The intake was cast by Ken Austin (Austin Rod Shop) in Oregon for me. It actually runs real well, after getting the correct jetting, power valves, etc.
A fellow in PA (Mike Suter) was a great help in telling me what was needed, and what modifications to make to get them to run properly. They are 1956 Ford 4 bbl carbs and needed some changes to run right/ The manifold is, as far as I know, the only one. It's marked ADQ1 (Austin dual quad #1) Regards Jim |
08-24-2014, 09:20 AM | #40 |
Re: Four barrel
Ran the Carter WCFB for many years on my 8-BA. No adapter needed. Fits right on the Offey intake like it was made for it. Great carb if you can find one.
