Old 12-02-2011, 01:42 AM   #1
Jeff M
Default Engine Oil/Brand?
I'm going to change the oil in my '31 Coupe for the first time tomorrow, what brand and weight are you guys using? Any Zinc additive and if so how much?
Thanks
Jeff M is offline   Reply With Quote
Old 12-02-2011, 01:47 AM   #2
40 Deluxe
Default Re: Engine Oil/Brand?
No zinc needed! No zinc in 1931 oil nor for years afterward. Believe zinc first was added in the '50's with the advent of OHV engines with their higher RPM's and heavier valve train needing stronger spring pressures.
40 Deluxe is online now   Reply With Quote
Old 12-02-2011, 01:55 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
Thanks
What brand - any
What weight - any
Zinc additive - if you want
All joking aside, any brand oil will work as will just about weight, straight from 30 - 50 has been used as well and any multi-weight 5-? has also been used. Some will say you need zinc some will say you don't. This is one of those topics that you will not get everyone to agree on, or even a majority to agree on.
Old 12-02-2011, 09:01 AM   #4
1931 flamingo
1931 flamingo's Avatar
Do a search. This has been discussed many times before with just as many recomendations.
Paul in CT
Old 12-02-2011, 09:06 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Shell Rotella 15-40, since if you use anything else, the engine will blow up. LOL
Old 12-02-2011, 09:12 AM   #6
MrTube
MrTube's Avatar
Originally Posted by Mike V. Florida View Post
What brand - any
What weight - any
Yep.
MrTube is offline   Reply With Quote
Old 12-02-2011, 09:24 AM   #7
mkmskm
mkmskm's Avatar
Any of the oils today are better than what they had back then (the dinosaurs have been dead longer). If the engine is fairly new and clean I would use detergent as often as the oil is changed, even without the filter.
mkmskm is offline   Reply With Quote
Old 12-02-2011, 09:30 AM   #8
George Miller
George Miller's Avatar
Smile Re: Engine Oil/Brand?
Tom is right I use 10w-40 Valvoline and did blow a engine at the hill climb. I will switch to Rotella. Thanks Tom
George Miller is offline   Reply With Quote
Old 12-02-2011, 09:38 AM   #9
sidevalve
sidevalve's Avatar
I also use the Rotella 15-40 as Tom said. I got this recommendation from previous threads on this site.
Matt from central Jersey
sidevalve is offline   Reply With Quote
Old 12-02-2011, 10:26 AM   #10
RonC
RonC's Avatar
Ford recommended S.A.E. 40 engine oil above 32 degrees
RonC is offline   Reply With Quote
Old 12-02-2011, 10:30 AM   #11
John Stone
John Stone's Avatar
If I don't use 40 wt. I use Wallyworld 20w50. Price is right and good oil.
John Stone is offline   Reply With Quote
Old 12-02-2011, 10:35 AM   #12
zzlegend
zzlegend's Avatar
Just as Tom said. I use it in 3 of my motors.
zzlegend is offline   Reply With Quote
Old 12-02-2011, 11:08 AM   #13
LukeDahlinger
Also a fan of Rotella. I run it in the Model A's and my 50s Fords as well for the past 15 years. Good stuff!!
Wanted- Feb. 1931 Parts Price List
www.vintagefordfacts.blogspot.com
LukeDahlinger is offline   Reply With Quote
Old 12-02-2011, 11:14 AM   #14
Kevin in NJ
Any oil can work, the question you need to ask is what can the oil do for the engine.
Detergents keep dirt suspended so it does not form gunk. It does not suddenly bring all the existing dirt in to the oil as some would lead you to believe.
Additives prevent the formation of acids and other nasty chemicals that can harm your engine. Keep in mind that a car that sits a lot will accumulate condensate just from daily temp changes. This water mixes with stuff in the oil to produce acids. You can see the cool etching in old oil pans from this acid. Other additives protect the babbitt.
Zinc is only need for engines with very stiff valve springs, not what you find in the A. The current zinc levels are what was in oil back in the 1950's.
So you can buy oil without detergent and non additives.
They make oil without detergent but with additives.
Then there is the common multi weight oils with detergents and additives.
To go one step further there are compression ignition (diesel) rated oils which are tailored to more additives to protect for acid and additives to protect the thicker babbitt layer found in diesel engines.
Changing the oil too frequently is a mistake. It cost you more money, does not really protect your engine more, and adds to the environmental waste.
The original interval was when decided when the oil was poor quality and the roads were dirt and life was hard for a car.
Oil companies have pushed shorter times between oil changes because they make more money.
The reality is I have never heard of an engine failing because of old oil. You may promote more wear, but how many years would it take to wear out the A engine at the rate most people drive their cars. I think people have this desired to do something to their cars so they believe an oil change, new plugs and points should be done every year.
Use common sense and learn what the oil does for you and select what you think will be good for you. It is hard to go wrong.
The best thing you can do is drive the car a lot.
Kevin in NJ is offline   Reply With Quote
Old 12-02-2011, 01:00 PM   #15
Purdy Swoft
Purdy Swoft's Avatar
I also use Walmart Super Tech 20w50 oil in my model A's
Old 12-02-2011, 05:20 PM   #16
ford1
super tech oil has the same warrenty ar shell, mobil, valvoline , havoline and castrol, the only difference is the price, use 20-50 and change it every 2000 miles, new cars use the same oil and they say change every 5000 miles, and the new motors put a hell of a lot more stress on the crank and every thing else in the motor than a model a will with its 4.5 to 1 compression, spend your money and listen to the hear say, or listen to the guys who run these things every day, oil never wears out it just get dirty
ford1 is offline   Reply With Quote
Old 12-02-2011, 05:25 PM   #17
CarlG
CarlG's Avatar
Chevron 10-30 by the case at Costco. Use it in all my vehicles.
Old 12-02-2011, 10:17 PM   #18
jr-41ford
jr-41ford's Avatar
I've been using various 30 wt oil, but now there is Walmart Super Tech in it.
Leaks about a tablespoon of oil per year, wish I could get it to stop at the back of the engine.
jr-41ford is offline   Reply With Quote
Old 12-02-2011, 10:40 PM   #19
Fred K-OR
Fred K-OR's Avatar
It would seem like a person should consider the weather they have in their area to determine what weight oil to use. For example, if your temps are around 0 F you may not want to use 40 weigh oil. Or is your temps are around 100 F you may not want to use 5 weight. So I would think a person should consider this when using a certain weight oil. So I assume the answer would be to use a multi weight, say 10-40, and that should cover most variations in temps. Just my guess on the subject!
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-03-2011, 12:50 AM   #20
Old182
Old182's Avatar
Good info. Many who were trained by the major oil companies believe, with good reason, that whatever oil you choose should have the API seal on it. While non-API oils can be excellent, they are not subject to the standardized testing that earns the API approval and therefore can vary their formulation from batch to batch. All the major brands and some not-so-major brands pass the tests and carry the API seal. It's really personal regarding the viscosity and straight weight vs multiweight, but definitely use a detergent oil - you need the additives for protection. Check the attached Texaco charts from 1930 to get an idea of what was recommended when our cars were new (Gosh I hope they show up).
Old182 is offline   Reply With Quote
