Old 01-28-2021, 08:46 PM   #1
46woodie
Default Headlight questions 46 Ford
Ok, I have new headlight harness and dimmer switch. Headlights only work low beam UNLESS I switch wires around on the headlights, then lights only work high beam. Have I miswired the dimmer switch? Thanks
46woodie is offline   Reply With Quote
Old 01-28-2021, 08:58 PM   #2
51woodie
51woodie's Avatar
Default Re: Headlight questions 46 Ford
Here is a picture of the dimmer switch in my '46 Coupe, and a wiring diagram.
File Type: jpg Flathead_Electrical_wiring1946-48car.jpg (94.2 KB, 22 views)
51woodie is offline   Reply With Quote
Old 01-28-2021, 09:40 PM   #3
paul2748
paul2748's Avatar
You might have the ground wire on the lights on the wrong terminal. Way back when, I had the same problem and I had the bubs wired incorrectly.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-28-2021, 09:46 PM   #4
46woodie
Thanks guys!!
