04-26-2015, 09:12 PM | #1 |
1933 Radiators Car vs Pickup
What are the differences in the two please? I have collected a variety but now I need one for the Roadster. Thanks in advance! Dennis
04-26-2015, 09:32 PM | #2 |
Re: 1933 Radiators Car vs Pickup
I always thought they were the same with different brackets for mounting the shell?
04-26-2015, 10:12 PM | #3 |
Brass works seems to have a good bit of information on this.
Car: http://www.thebrassworks.net/shop/Re...cf4a157d6955a0 Truck: http://www.thebrassworks.net/shop/Re...cf4a157d6955a0 Hope this helps, they list this as a truck radiator though. I'm not sure if they are referring to a bigger truck or a pickup. I don't know if or what the differences might be between truck and pickup. Last edited by PhoenixFear; 04-26-2015 at 10:18 PM. |
04-26-2015, 10:15 PM | #4 |
Krylon32 is correct. I used a car radiator in my truck. All I had to change is the brackets bolted to the side of the radiator.
Matt 24:36-41 |
04-27-2015, 12:06 AM | #5 |
I posted this question some time ago on the HAMB, all the replies
back were that they are the same. |
04-27-2015, 07:10 PM | #6 |
04-27-2015, 08:36 PM | #7 |
The V/8 Radiators are the same,but the sides are not,so in order to use a car radiator in a pickup you would have change the radiator sides so the grille mounting brackets can be attached to mount the pickup grille,and vise-a-versa when using a pickup radiator for a car,so the car grille can be attached.I hope this helps.E.P.Williams
