Old 04-18-2014, 03:35 PM   #1
mcgarrett
Default 33 Model B pickup rear axle
Did the 33 Ford Model B 1/2 ton pickup use the same rear axle as the V8 trucks? Would like to change rear gearing to a 3.78 ring & pinion when I changed my 40 Ford to a 3.54. Any fit issues here?
Thanks for any info.
mcgarrett is offline   Reply With Quote
Old 04-18-2014, 07:17 PM   #2
PeteVS
PeteVS's Avatar
Default Re: 33 Model B pickup rear axle
V8 and four cylinder had different lengths for the torque tube / driveshaft. There was a thread several years ago where a guy had the wrong set up for the engine in his truck. Big can of worms!
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 04-19-2014, 07:31 AM   #3
jimTN
late 32-4 v8 rear ends are not as wide as the 36-48 center sections so you either have to change the r&p in what you have or find a original set up with 3:78 gears.
jimTN is offline   Reply With Quote
Old 04-19-2014, 08:38 AM   #4
mcgarrett
My main concern is if the ring and pinion gears are the same as the v8. If so, I just want to switch them out for higher speed 3.78 gears from a 40 Ford. A model A guy told me the 33 half ton model B truck used the same rear end as a model A.
I seriously doubt that.
Old 04-19-2014, 08:56 AM   #5
Kurt in NJ
Kurt in NJ's Avatar
If the flange where the torque tuber joins the banjo is round then it is the "A" style, if it is scalloped it is the V8 style , gears from a 40 are not a direct fit in a 32-34 banjo, the 40 banjo is wider than the 32-34 ---if you do a search about it there will be descriptions of the modifications to the ring and pinion to make it fit the early banjo---the tips of some teeth need to be ground off and there is some work on pinion for a spacer I think.
cars and light pickups share mechanical parts
Old 04-19-2014, 09:47 AM   #6
PhoenixFear
The torque tube and driveshaft are about 1 3/4" shorter than V8. I do not think the banjo itself is different but I have yet to swap gears in mine. There are readily machined 10 spline ring and pinions available now for the late 32-early 35 banjo rear ends, costly but better than buying the late 35-up gears and machining them. Those should work whether or not it originally came with a V8.
PhoenixFear is offline   Reply With Quote
Old 04-19-2014, 10:34 AM   #7
DavidG
DavidG's Avatar
The ring and pinion gears are the same dimensionally as the V-8, as is everything behind the driveshaft and torque tube (only those two items differ between the four-cylinder and V-8 axles during the '33 and '34 model years).
Old 04-19-2014, 10:56 AM   #8
mcgarrett
Thumbs up Re: 33 Model B pickup rear axle
Sounds reasonable that Henry would use the same rear axle as the V8 for the Model B since the major drivetrain components changed when the V8 came out - the Model B also used the V8 transmision.
Thanks for all the great feedback!
Old 04-19-2014, 11:43 AM   #9
Charlie Stephens
Minor correction on the transmission, the Model B used the same gears with a different case.
Charlie Stephens
Old 04-19-2014, 01:39 PM   #10
PeteVS
PeteVS's Avatar
#1: An EARLY '32 rear is internally the same as a Model A but the driveshaft and spring mounts differ. Nothing early '32 swaps with late '32 or later.
#2: The late '32 through '34 banjo casting differs from the '35 through '48 casting. Because of this, your ring and / or pinion from the '40 will have to be modified to fit your '34 banjo housing and axle housings.
#3: Your '40 in its entirety should work in your '34 pickup WITH the correct length drive shaft / torque tube AND a change to a STRAIGHT spring. Either the rear crossmember will have to be modified to accept the spring or the spring will have to be modified to fit the rear crossmember. I don't think that your existing '34 torque tube will work on the '40 rear to fit.
Old 04-19-2014, 04:23 PM   #11
jimTN
No, the 34 TT does not work with the 40 center section cause the center section islonger than the 34. As I said earlier, you either go with a late 32 v8 or 33-4 3:78 if you want things to fit right. If you want to butcher your truck with a straight spring and have the wheels not where they belong then use a 40 rear end.
