03-05-2016, 09:03 AM | #1 |
Fender bead repair
Does anyone have experience using all or a portion of the front fender bead repair sold by Snyder's? Is the bead correct?
http://www.snydersantiqueauto.com/fr...d-repair-panel |
03-05-2016, 09:14 AM | #2 |
Re: Fender bead repair
I'm sorry but I don't but I would think it would be easier to repair the bad section. I find it hard to believe that the entire edge would be bad but the rest of the fender good.
03-05-2016, 09:53 AM | #3 |
Find a junk fender and cut out a section.
If you were close to me I have some junk fenders cheap. |
04-18-2016, 04:15 PM | #4 |
you may also look here. http://www.modelahouse.com/tech/fender/fender1.html real professional looking job.
GDG |
04-19-2016, 03:55 AM | #5 |
Theirs is close but no cigar unless changed in the last few years
But small. Find the correct curvature off a donor fender and splice. It generally works better to splice in a small piece than try to deal with what's there especially if anyone has bugger with it before! |
04-19-2016, 08:20 AM | #6 |
Why is it better to cut out a crack and weld in a larger patch that gets welded on three sides, instead of welding one line of a crack. I understand wanting a wire in the bead that goes beyond the crack, but that involves unrolling the edge and splicing in a short length of new wire. |
04-19-2016, 09:52 AM | #7 | |
He does not state what he is trying to fix. So the best we can do is answer is question. |
04-20-2016, 01:07 AM | #8 | |
Now by placing a piece of "virgin" metal at that stress location will keep the crack from following any hardened metal weld. Like I said that is how I understand it.
