07-03-2012, 08:25 AM | #1 |
HAVE to get some primer on my tins
All the body work is done on my tins and have been fitted up on the truck. Its been two months since they have been sand blasted and Im thinkin I need to use an epoxy primer before I blow the filler primer on. I dont see any real flah rust, but Im sure its begining.
07-03-2012, 12:21 PM | #2 |
Re: HAVE to get some primer on my tins
Yep sounds like a good thing to do. Any flash rush?
07-03-2012, 01:13 PM | #3 | |
Pluck |
07-03-2012, 01:58 PM | #4 |
Not yet that I can see. But the tins had alot of pitting before sand blasting. Looked like most of the black was out of the deep pits, but you know how rust is. Im just gonna shoot it with epoxy primer. To much work to have rust come through 2 years down the road. I would post pics, but I cant figure this forums system out.
07-03-2012, 02:02 PM | #5 |
What is a "tin"???
07-03-2012, 02:10 PM | #6 |
Check the paint manufacturer's data sheets.
The pursuit of excellence is healthy and rewarding. The pursuit of perfection is frustrating, neurotic and a terrible waste of time. |
07-03-2012, 02:22 PM | #7 | |
Was planning on using a filler primer over the epoxy primer. I'm too slow to shoot everything wet, so was planning on having to scuff after shooting. I really apologize about the "TINS" terminology. Old habit from working on motorcycles......... |
07-03-2012, 05:14 PM | #8 |
I would clean the steel witha 3M scuff pad and then wipe a solvent based wax and oil grease remover over the parts. I would then wipe them down with a water/acetone based wax oil and grease removwer. Shoot the parts with a good epoxy and when that dries give them a coat of 2K primer. Then all you need to do is work over the top of the 2K which is easier to sand.
07-03-2012, 05:21 PM | #9 |
Tins refers to any removable metal work. For instance on a motorcycle, the tins would be the tank, fenders, etc.
07-03-2012, 05:28 PM | #10 |
07-03-2012, 05:29 PM | #11 | |
07-03-2012, 06:22 PM | #12 |
We usually prime them right after sand blasting... It's probably a Texas thing, but you can literally watch rust form hours after you touch the bare metal.
Cowtown A's |
07-03-2012, 07:53 PM | #13 |
My concern is the pits after sand blasting and sitting for some time. The rust will start down in the pits and later may pop up or cause problems. I use a phosphoric acid product and soak it for 20 minutes or so to remove the rust. You will be able to tell when it is working. Epoxy primer should work fine over that, but I go ahead and spray the sandable primer on during the recoat period of the expoxy primer. Save your self the tough sanding of the epoxy.
07-03-2012, 08:11 PM | #14 | |
07-03-2012, 11:19 PM | #15 |
only use wax and grease remover for wax and grease not to clean the metal before primering, get some ppg metal treatment and wear gloves use a 3M scuff pads, use it straight go over the whole parts and have a bucket of clean water and a clean rag rinse the part and dry it as fast as you can they should give you a poop sheet and read it.
07-04-2012, 07:59 AM | #16 | |
07-04-2012, 08:16 AM | #17 |
you can use DX520 over filler with out any problems just make sure you rinse it and that it is totally dry before you put primer on.
07-04-2012, 08:44 AM | #18 |
07-04-2012, 01:45 PM | #19 |
Doors after DX520.......................Everything is goin in the house lol.
