Old 10-29-2023, 07:15 PM   #1
Lamar Wadsworth
Lamar Wadsworth's Avatar
Default '55-56 Throttle arm
I wasn't paying attention I pulled the 272 out of my '55--forgot to unbolt it where the bracket bolts to the back of the block and broke the bracket. Does anybody have a decent on a parts car? I know '55 and '56 V8 cars are the same, probably '54 V8 as well. This is the bell crank thing--the part that points down has the rod that goes up through the toeboard and has the button that the accelerator pedal attaches to. The linkage to the carb attaches to the part that points up.
Lamar Wadsworth is offline   Reply With Quote
Old 10-30-2023, 09:13 AM   #2
Patrick brophy
Default Re: '55-56 Throttle arm
Patrick brophy is offline   Reply With Quote
Old 10-30-2023, 06:04 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
If this is the broken part (see attached photo), I have an extra one
Please measure between top rivet and center of large round collar where end of bellcrank goes in. (They made different lengths, 54/55/56 are same, but 57/58/59 have a longer spring-steel piece. I have both.
Daves55Sedan is offline   Reply With Quote
Old 10-30-2023, 06:14 PM   #4
Lamar Wadsworth
The one that Patrick posted is the right one. I broke the bracket that bolts to the top of the block behind the intake.
