Old 11-25-2012, 04:19 PM   #1
jbond
Default What's this hose?
I seen a few Model A's that have what might be a road draft tube attached to the oil filler tube. What is the hose for? And why would someone want one of these?
Thanks
Herb
jbond is offline   Reply With Quote
Old 11-25-2012, 04:27 PM   #2
Rowdy
Default Re: What's this hose?
Hard to tell in that picture, but it loos like they ran a wire through it to keep tit from chafing. Definately not a stock setup under the hood other than the engine itself. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 11-25-2012, 04:28 PM   #3
Fred
The BIGGER ??? Why would someone want all the other STUFF shown ??
Fred is offline   Reply With Quote
Old 11-25-2012, 04:28 PM   #4
Russ/40
Russ/40's Avatar
Gets the oily blowby fumes out of the engine compartment, and helps keep them out if the car.
Russ/40 is offline   Reply With Quote
Old 11-25-2012, 04:32 PM   #5
Kevin in NJ
The tube takes the crankcase blow by, which can have oil in it, out under the car.
The oil tends to coat the firewall and is more prevalent in cars with loose rings and the wrong baffles in the oil filler tube. Ford went through several variations of oil filler tubes while trying to minimize the oil coming out. I believe an article on this was run in one of the national club magazines.
From the looks of this guys car he is trying to protect a lot accessories.
Can we count them all? (this is just for fun on a cold day and I am not picking on the guy or saying anything here is bad)
Remote starter switch
battery disconnect
alternator
temperature gauge
manifold heater
I do not know what the little white thingy is in the lower right. Something is odd with the wires running to the horn and or lights on the lower left. I am guessing he has turn signals too.
I am impressed the car has engine splash aprons.
Looks like the guy drives his car, which is what is ment for doing.
Kevin in NJ is offline   Reply With Quote
Old 11-25-2012, 04:32 PM   #6
Steve Wastler
Steve Wastler's Avatar
Probably a very road worthy model A, but WOW, so much for the simplicity......
Steve Wastler is offline   Reply With Quote
Old 11-25-2012, 05:38 PM   #7
jbond
Thanks for the help. I'm looking for an A and this one was on Craigslist. There's a few more pictures. It's pretty nice but certainly not stock.
http://dallas.craigslist.org/dal/cto/3419865371.html
Old 11-26-2012, 03:55 PM   #8
lupie989
It is a crankcase breather tube.
lupie989 is offline   Reply With Quote
