Old 05-26-2014, 06:14 PM   #1
Jon-Ohio
Default Horn motor dropping resister
For a horn motor - What size power resister is needed to drop 12V to 7V(not 6). The motor draws 7.2 amps under load ?
thanks for any help on the mathematics
Jon in Ohio
Jon-Ohio is offline   Reply With Quote
Old 05-26-2014, 06:21 PM   #2
crock
crock's Avatar
Default Re: Horn motor dropping resister
I purchased an adjustable resistor ohmite #588-d100k2reo 100wat, 2ohm 10%. Ordered from mouser electronics www.mouser.com works just fine.
MY PROBLEM CHILD!
crock is offline   Reply With Quote
Old 05-26-2014, 06:47 PM   #3
marc hildebrant
marc hildebrant's Avatar
Jon in Ohio
Ohms law : V=IR
V in volts, I in amps, and R in ohms.
Marc
marc hildebrant is offline   Reply With Quote
Old 05-26-2014, 06:55 PM   #4
nstegall
Jon,
The best way to solve your horn problim is to have your horn rewound for a 6 volt system. These voltage dropage units, as a rule are no more than a bandaid fix.
Regards,
Neil
THE HORN MAN
601-469-0878
[email protected]
nstegall is offline   Reply With Quote
Old 05-26-2014, 06:57 PM   #5
steve s
steve s's Avatar
Originally Posted by marc hildebrant View Post
Ohms law : V=IR
Marc
Just to clarify what Marc said, the relevant voltage in this case is the voltage DROP that you want the load resistor to accomplish. So, if you want 12 volts dropped down to 7, that's a drop of 5. Or, if your alternator is humming along at say 14 volts, that's a drop of 7. In practice, I suspect that anything around 1 ohm would work fine.
steve s is offline   Reply With Quote
Old 05-26-2014, 10:56 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Why 7?
Old 05-27-2014, 11:34 AM   #7
Richard in NC
Some people use the primary winding of an old ignition coil for the resister. Mount it in the frame where it won't be seen.
Richard in NC is offline   Reply With Quote
Old 05-27-2014, 02:20 PM   #8
mrtexas
mrtexas's Avatar
Jon in Ohio
Why not buy one of the nice resisters the usual suppliers sell that has fins on it for cooling? About $20.
mrtexas is offline   Reply With Quote
Old 05-27-2014, 09:12 PM   #9
Jon-Ohio
Thanks for all the info. I'm going to try and get a 1 ohm/ 50 watt resister at a local surplus electronics store and see if that works.
Jon in Ohio
