05-14-2021, 04:50 PM | #1 |
Rear hub sleeved wheel bearing faliure
I had my '28 rear hubs sleeved with the repair kit. It now uses '36-'48 Ford rear wheel bearings ?
If you've had this done did you have any problems with new bearing failure of either cage end because they were not hardened ? Seems as though the problem is not the rollers but the ends (thrust bearing). Also if you've had it done with no problems who supplied the bearings. |
05-15-2021, 07:02 AM | #2 |
Re: Rear hub sleeved wheel bearing faliure
