09-26-2015, 04:02 PM | #21 |
Re: model b engine and 32 trans in a model a frame
Overdrive drive shaft installed. Way too much fun. I had straps and ropes holding things up and pulling things together. I just want to mount a seat on it and go for a ride. Next I will support transmission, wishbone, and mount clutch and brake pedals.
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ |
09-28-2015, 04:23 PM | #22 |
I have been checking with all the antique parts companies and it seems that the kit that was used to install the model b and 32 tranny is discontinued. if any one has one I can copy I would be much in their debt. other wise I will have to get creative and build my own.
09-30-2015, 05:47 AM | #23 |
Today I will attempt to install the 32 pedal bracket in the car. I will take some pictures if it goes well.
09-30-2015, 12:36 PM | #24 | |
Charlie Stephens |
09-30-2015, 03:08 PM | #25 | |
My application is different than yours but we used '32 pedals with a Tardell '32 type k member. Our set up is a '35 transmission, '48-'52 F1 bell housing and 8ba engine and ran into a similar issue you're facing with the wishbone mount. Ended up fabricating a "belly band", something not uncommon in the old days. With regard to your earlier post about making something, we started with cardboard, and then made a mock up with 1/4" or 3/16" foam core. We used that as the pattern for the piece. |
09-30-2015, 06:16 PM | #26 |
10-02-2015, 10:07 PM | #27 |
Here are some oistures of the new tranny bracket I made.
10-04-2015, 08:35 AM | #28 |
Wishbone support all made. I used a piece off1/4 inch plate and mounted it to the under side of the transmission. Then I put 2- 1/2 inch holes and 1- 3/4 inch hole to mount the 32 wishbone ball support.
10-04-2015, 10:49 AM | #29 |
What were you charging for it?
10-05-2015, 11:57 AM | #30 |
Do you think I should weld a couple of gussets into my wishbone support. I used 1/4 in steel.
10-10-2015, 07:45 AM | #31 |
Back from Hershey with a whole lot of parts, time to get busy!!!
10-10-2015, 12:45 PM | #32 |
