09-05-2017, 02:21 PM | #1 |
Removing Doors on 1934 3 window
Looking for advice: I will be removing the doors on my 1934 3 window to do some paint work on the body in the next week. In the past I have just removed the door pins on other cars but since this car is finished and this job will not be a complete repaint and will not include the doors. I was wondering if would be better to just take the hinges off from the doors or the body instead.
09-05-2017, 02:25 PM | #2 |
Re: Removing Doors on 1934 3 window
I would personally just take out the pins. I think you would have less chance of fitting issues later. Carefully soak for a couple of days as they may be tight.
09-05-2017, 02:27 PM | #3 |
If you don't need to paint the hinges, pulling the pins will save the hassle of realigning the doors.
Enjoy yer day. Tom Hate can't fix what it started. |
09-05-2017, 02:42 PM | #4 |
Not sure on the 3 windows, but believe the 5 window has the hinge spot welded to the door. The screws into the door frame can be very difficult to remove.
09-05-2017, 03:26 PM | #5 |
