Old 06-06-2021, 07:20 PM   #1
pebo va
Default "49 Distributor Timing Issue
I have a distributor problem on my stock "49 Ford wagon. I am experiencing a power loss when I accelerate. I believe I have figured out the problem but I don’t know how to make the correction. I am pretty sure it is a timing issue.
When I line up the pointer with the bump on the bottom pulley,
the rotor is pointing at number 1 plug. With the timing light I can see that it is advanced about 2-3 degrees. I find that the best setting is retarded about 4 degrees. But I cannot rotate the distributor counterclockwise to retard it because the vacuum canister is hitting the head. What is the solution?
Thanks for any advice.
pebo va is offline   Reply With Quote
Old 06-06-2021, 07:27 PM   #2
cadillac512
cadillac512's Avatar
Default Re: "49 Distributor Timing Issue
The distributor turns clockwise,so turning the housing counter clockwise will advance the timing. If you need to retard it, you'll have to turn the housing clockwise, same as rotation direction.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 06-06-2021, 08:16 PM   #3
pebo va
Sorry. I mistyped my question. I want to advance the timing about 4 degrees by turning it counterclockwise. Not retard it.
Thanks.
Old 06-06-2021, 08:42 PM   #4
JSeery
JSeery's Avatar
Well, you need to pull the distributor and move the gear a tooth and reinstall it. What is the timing at around 2000 to 2500 rpm?
Old 06-06-2021, 09:34 PM   #5
Ken Henry
Ken Henry's Avatar
Are you actually getting advance with rpm/vacuum? The passages in the carb can become clogged...
Ken Henry is offline   Reply With Quote
Old 06-06-2021, 09:56 PM   #6
pebo va
Which way do I turn the rotor to change one tooth?
I don't have a tach to measure RPM. The carb is fine. No problem here.
Old 06-06-2021, 10:10 PM   #7
JSeery
JSeery's Avatar
Now how do you know it's fine if you can't check it. Initial timing shouldn't make all that much difference. Your issue with acceleration could be the advance canister or the carburetor itself. You need a dial back timing light, but not easy to come by for 6v.
Need to come up with a way to map the timing curve out (roughly) to see what is going on.
Old 06-07-2021, 05:11 AM   #8
51 MERC-CT
51 MERC-CT's Avatar
This could also be a problem with the accelerator pump in the carb.
If it is not already there try moving it to the next richer position.
Old 06-07-2021, 05:21 AM   #9
V8 Bob
V8 Bob's Avatar
Make sure the point dwell is correct @ 27 degrees before making any timing changes.
V8 Bob is offline   Reply With Quote
Old 06-07-2021, 07:15 AM   #10
Frank Miller
Frank Miller's Avatar
Just hook the light to a 12 volt source. Not hard to do. The modern car pulled next to it works fine. The spark trigger does not care.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 06-07-2021, 08:52 AM   #11
Ol' Ron
Ol' Ron's Avatar
The only way to check these distributors ,is with a distributor machine with variable vacuum source, This is a vacuum advance distributor, and it sounds like your not getting the advance.
Gramps
Old 06-07-2021, 10:03 AM   #12
Ken Henry
Ken Henry's Avatar
There are two tiny passages in the carburetor - one to manifold vacuum and one going to venturi vacuum. If they are plugged it will run smoothly enough but be a dog because you are not getting any rpm based advance (this is what the venturi vacuum signal accomplishes, since it rises with RPM even when the throttle is wide open). A quick check is to see if the timing advances when revving up engine in neutral. A distributor machine will tell you if the advance is in spec, but can't tell you if those passages are plugged. These passages were clogged with crud on my engine when I first got the car, and fixing this issue made a huge difference!
Old 06-07-2021, 11:41 AM   #13
flatjack9
flatjack9's Avatar
Remove the dist cap and advance line. Using a hand held vacuum pump, pump it and see if the dist plate moves. That at least will verify that the can is good.
Old 06-07-2021, 12:02 PM   #14
scicala
scicala's Avatar
You can use any timing light on a 6 volt car. You just hook up the power leads to a 12V battery or have a 12V car next to it.
Sal
Old 06-07-2021, 12:51 PM   #15
Ol' Ron
Ol' Ron's Avatar
I like the hand held vac pump. Much simpler for checking dist advance. If the distributor works check carb???
G
Old 06-07-2021, 01:35 PM   #16
JSeery
JSeery's Avatar
Thanks for the correction/ update. I knew that, but my mind does not always completely engage!
