Old 02-19-2015, 05:08 PM   #1
Tony S,Fl.
Tony S,Fl.'s Avatar
Default Clacking sound.
A fellow joined our club yesterday and wanted a opinion on his engine. 28 tudor . Parking brake on left side. At idle it clacks. not knock but clatty clack. Sounds like its coming from #1 or 2 cylinder area. Loose valve seat or broken valve spring ? At speed it's quiet other than a clack now and then. At idle clack clack clack.Gas tank wouldn't flow till we put compressed air through the line from carburetor to tank.We know how to clean the crap out. Just wondering about the duck in the engine. Thanks Tony
Tony S,Fl. is offline   Reply With Quote
Old 02-19-2015, 05:55 PM   #2
G Baese
G Baese's Avatar
Default Re: Clacking sound.
Tony-
1f, at idle it quacks. Not a knock but quackity quack. Sounds like its coming from #1 or 2 cylinder area... At speed it's quite, other than a quack now and then, and at idle quack quack quack, and you are just wondering about the duck in the engine.
Check to see if the exhaust manifold gasket is quacking around #1 and 2. if not, remove the valve chamber cover and look inside for evidence of a quack, and if that doesn't reveal anything, taking the head off is the best way to get the duck out.
TIC, and Good luck,
gb
G Baese is offline   Reply With Quote
Old 02-19-2015, 06:50 PM   #3
bikejunk
could the quack be a spark plug leak or an exhaust manifold leak? is it worse when cold?
bikejunk is offline   Reply With Quote
Old 02-19-2015, 07:36 PM   #4
edmondclinton
Does the sound increase as the spark is advanced or decrease as the spark is retarded? Does the sound get quieter after the engine warms up?
edmondclinton is offline   Reply With Quote
Old 02-19-2015, 08:04 PM   #5
Patrick L.
Patrick L.'s Avatar
I'd recommend isolating the noise a 'little more better'. A stethoscope, big screwdriver, dowel, etc can be used to try to pin point the noise.
It could be many things, as said. Excessive valve lash, broken spring, exhaust leak, timing gear, etc.
Old 02-19-2015, 08:09 PM   #6
Rowdy
Take the fan belt off and start it briefly and see if it goes away. That would eliminate the waterpump and generator. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 02-19-2015, 08:24 PM   #7
DANA BIZZELL
DANA BIZZELL's Avatar
Tony, I had a crank shaft pulley cracked and was making a clacking sound.
Thanks
Dana
DANA BIZZELL is offline   Reply With Quote
Old 02-19-2015, 08:28 PM   #8
Greg Jones
Greg Jones's Avatar
Since we are stabbing in the dark here, how about loose engine pans? I had a horrible loud squealing that sounded like the driest of dry bearings burning itself to pieces. Turned out to be a loose bolt on an engine pan setting up a "harmonic" vibration. Of course yours is a "clack" but might be worth checking as other guys have told me they have had loose engine pans make all kinds of oddball noises.
Greg Jones is offline   Reply With Quote
Old 02-19-2015, 08:29 PM   #9
Archie Cheda
Archie Cheda's Avatar
My "clack" at idle turned out to be a loose valve seat insert.
Archie Cheda is offline   Reply With Quote
Old 02-19-2015, 09:01 PM   #10
tbirdtbird
pull one wire at a time to see if the clack goes away. IOW try to localize the noise.
Having said that, it doesn't always work.
Could be piston slap, too. Engine recently overheat??
you will end up pulling the VC and the head
'31 180A
tbirdtbird is offline   Reply With Quote
Old 02-19-2015, 11:51 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
You can buy 3/8" ID clear hose cheap at Menards. Use about a 3 foot piece, hold one end in your best ear, and move the other end around the engine to locate the noise.
Old 02-20-2015, 12:20 AM   #12
SeaSlugs
SeaSlugs's Avatar
does it clack upon engine deceleration? like build up rpm then let off the gas fully.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-20-2015, 12:48 AM   #13
pat in Santa Cruz
pat in Santa Cruz's Avatar
a loose timing gear will sound like all the valves are loose when idling, but gets more quiet at higher RPM
pat in Santa Cruz is offline   Reply With Quote
Old 02-20-2015, 09:02 AM   #14
larrys40
I agree with pat above that I would check the timing gear first , reverse the pin while the engine is running and put inward pressure against the gear and see if it quiets down . You migt want to remove the fan belt first for safety , up to you .
If it gets quieter you know it is the timing gear .
You can pull the side inspection cover and also see how the teeth are and if it moves fore and aft .
Larry Shepard
larrys40 is offline   Reply With Quote
Old 02-20-2015, 09:53 AM   #15
juke joint johnny
juke joint johnny's Avatar
If the generater has one of the pressed steel pulleys on it, some times the rivets work loose and that can produce a claking sound .
John Cochran
juke joint johnny is offline   Reply With Quote
Old 02-20-2015, 10:33 AM   #16
CarlG
CarlG's Avatar
I had a clacking sound like that. It would stop after maybe 30 seconds or so. Found out later that it was a couple of valve inserts that had come loose, #3&4 Exhaust.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-20-2015, 11:38 AM   #17
Cool Hand Lurker
Cool Hand Lurker's Avatar
Like Rowdy says, taking off the fan belt is the first thing you should do for a couple of reasons. Besides indicating whether the water pump and generator are the cause, it is easy to do. And it gives you the opportunity to check out the fan for cracks near the center. Check the generator and fan pulleys for looseness, cracks or misalignment. These things can create sound when they are rotating. Check the water pump shaft for bearing wear and fore and aft movement. Too much movement will cause the end of the shaft to bang against the inside of the head casting and cause that sound.
Cool Hand Lurker is offline   Reply With Quote
Old 02-20-2015, 12:41 PM   #18
Mikeinnj
Mikeinnj's Avatar
Originally Posted by g baese View Post
tony-
Check to see if the exhaust manifold gasket is quacking around #1 and 2. If not, remove the valve chamber cover and look inside for evidence of a quack, and if that doesn't reveal anything, taking the head off is the best way to get the duck out.
Tic, and good luck,
gb
Not quacking - c l a c k i n g ....as in clickity clack .
Mikeinnj is offline   Reply With Quote
Old 02-20-2015, 01:12 PM   #19
Patrick L.
Patrick L.'s Avatar
Some responses just quack me up !
Old 02-20-2015, 03:36 PM   #20
buddridge
This thread brought this to mind....old but still funny.
Model A Engine Repair Price List
PING-PING-PING...............$35.00
PLUNK-PING-PLUNK..........$50.00
KLUNK-PING-KLUNK........$125.00
THUD-KLUNK-THUD.........$200.00
CLANK-THUD-CLANK.......$325.00
Careful if you're going to follow the Masses.....sometimes the M is silent.
buddridge is offline   Reply With Quote
