Old 08-14-2021, 01:40 PM   #1
Russ/40
Russ/40's Avatar
Default 28/29 OCPU Top Bows / Irons
I have an incomplete set of top irons for my OCPU. The top center bow is missing.
Also, I have two wood bows with the set that are different lengths. I am looking for
measurements for the rear top wood portion of the rear bow so I can determine which
wood bow is correct.
Also, any way I can distinguish Roadster irons from Roadster Pickup irons and which pieces are common to both vehicles, if any.
Help would be greatly appreciated.
Old 08-14-2021, 01:57 PM   #2
wrndln
Default Re: 28/29 OCPU Top Bows / Irons
Roadster and OCPU top irons are totally different. Original OCPU top irons do NOT fold down.
Old 08-14-2021, 02:32 PM   #3
Russ/40
Russ/40's Avatar
Any dimension you can add? Total length of the wood rear bow?
Old 08-14-2021, 03:45 PM   #4
wrndln
I had a decent set of OCPU top irons, but sold them about 3 years ago. The OCPU top irons have a lot of steel and not much wood. The middle bow is made of metal. The only bow that is wood is the rear most bow. I tried attaching some pictures of the irons I use to have, but Fordbarn photo uploader kept failing. I didn't measure the wood bow before I sold the irons. If you send me your email address I can send you the pictures I have if you want them.
Rusty Nelson
