Old 08-06-2021, 08:53 PM   #1
STAN WHITE
Default 1934 radiator
Does anyone out there have a picture of a 34 radiator that shows the location of the side brackets? Thanks Stan
STAN WHITE is offline   Reply With Quote
Old 08-07-2021, 10:49 AM   #2
JSeery
JSeery's Avatar
Default Re: 1934 radiator
Old 08-07-2021, 11:39 AM   #3
STAN WHITE
J if you sent me something it did not come thru! Thanks Stan
Old 08-07-2021, 12:11 PM   #4
deuce_roadster
deuce_roadster's Avatar
i could measure my 33 from the top of the mounting bracket to the frame up, but it might not be the same as 34.
Old 08-07-2021, 01:15 PM   #5
JSeery
JSeery's Avatar
No, I removed what I started to post. I was thinking the two frame brackets between the crossmember and the frame rail, not the brackets on the side of the radiator.
