Old 07-19-2021, 12:53 PM   #1
STAN WHITE
Default 12 Volt Bosch blue coil PN-00012
I am having a hard time locating this coil. Buba recomends them. Does anyone know where I can buy a couple of them. Other than E Bay ? Thanks stan
STAN WHITE is offline   Reply With Quote
Old 07-19-2021, 01:04 PM   #2
tubman
tubman's Avatar
Default Re: 12 Volt Bosch blue coil PN-00012
https://www.amazon.com/Bosch-00012-I...s%2C196&sr=8-5
They say they have 3 left and they are discounted.
Old 07-19-2021, 01:24 PM   #3
51504bat
51504bat's Avatar
Lots of VW/Porsche suppliers list them.
Old 07-19-2021, 07:37 PM   #4
Crankster
Crankster's Avatar
The Bosch "Blue" coil is nominally 3 ohms, one thing I can't figure out is why Bubba doesn't recommend a coil closer to the OEM value when used with points & switched ballast. Ford used (about) 1.4 ohm coils with an external ballast resistor for many years in 12 volt systems. So for these applications, it would seem like the Bosch "Red" coil of 1.8 ohms would be the logical choice?
Crankster is offline   Reply With Quote
Old 07-20-2021, 09:54 AM   #5
STAN WHITE
I am going to use the Blue Coil PN-00012 . As per Buba! I hope he replys !. Now I am concerned ! I hope Buba can make me feel better. Thanks Stan
Old 07-20-2021, 09:57 AM   #6
STAN WHITE
I should have stated that I am running a Harmon & Collins Dual Coil Disributor Stan
Old 07-20-2021, 09:58 AM   #7
STAN WHITE
Also with Bubas Condensers! Stan
Old 07-20-2021, 11:04 AM   #8
tubman
tubman's Avatar
Stan, are you sure? I know you bought a couple of condensers from me. I don't think Bubba offers them.
Old 07-20-2021, 11:23 AM   #9
flatjack9
flatjack9's Avatar
There were no early Fords with a 12 v,. supply. When changing over to 12 volts, this is the coil to use dump and any resistor in the circuit.
Old 07-20-2021, 12:35 PM   #10
35fordtn
35fordtn's Avatar
I've been using the black 00012 same coil just oil filled instead of epoxy..
Old 07-20-2021, 01:26 PM   #11
flatjack9
flatjack9's Avatar
I've had good luck with the Beru 12 v. blue coil and it's half the price of the Bosch.
Old 07-20-2021, 03:31 PM   #12
STAN WHITE
Tubman, You are correct, Sorry I bought them from you. As you get older you make more errors. Sorry . Stan
Old 07-20-2021, 05:58 PM   #13
Crankster
Crankster's Avatar
No there weren't any early Fords with a 12 volt supply, but that really isn't a factor. When Ford did change to 12 volts, they used an ignition coil with an approximately 1.4 ohm primary winding and a divider network utilizing an external ballast of approx 1.5 ohms that only switched in after engine start. See where I'm goin' with that?
A 3 ohm ignition coil could in theory have more difficult cold starts, or possibly when flooded. Ford set up their 12 volt ignitions the way the did for a reason, all cars and trucks from 1957 to 1974 basically. Many other makes and models did exactly the same thing.
Old 07-20-2021, 06:27 PM   #14
tubman
tubman's Avatar
Don't I know it. I just wanted to make sure everyone was aware of the exact parts being used so they can give the best possible advice.
I can't wait to see the finished product!
Old 07-20-2021, 07:46 PM   #15
flatjack9
flatjack9's Avatar
In theory it could, but it also introduces another part that can be prone to failure.
Old 07-20-2021, 07:54 PM   #16
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I have always stocked the Vertex Magneto condensors. Never seen a defective one ... .36 mfds
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-20-2021, 07:57 PM   #17
BUBBAS IGNITION
Yep i am hooked on the Bosch blue coil at 3.0 ohms , been buying them from amazon . I have also used the beru blue coil , a little less ohms but a good unit as well......
[email protected]
Old 07-20-2021, 08:02 PM   #18
Crankster
Crankster's Avatar
I've heard of Ballast resistors going bad occasionally but I don't think it's a cause for concern. Ford didn't seem to think so either (nor GM or Chrysler etc..) Remember this was THE classic points and condenser wiring circuit for millions and millions of cars and trucks, back when hollow state igntion ruled the roost.
Old 07-20-2021, 09:48 PM   #19
flatjack9
flatjack9's Avatar
To each his own.
Old 07-21-2021, 08:22 AM   #20
A bones
A bones's Avatar
A failed ballast resistor had me hitchhiking to work one morning.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
