Old 07-22-2020, 07:31 PM   #1
cvicky
cvicky's Avatar
Default 57 ford went of the road
my 89 van lost rear brakes because of rusty lines, No problem ,dual master cylinder, so i'll go home to replace line.
as i'm backing up ramps front lines burst because of rust "NO BRAKES"
not a good feeling , but i was able to limp with emergency brake
glad i wasn't on a curvy hilly road like 57 ford
cvicky is offline   Reply With Quote
Old 07-22-2020, 07:44 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: 57 ford went of the road
You should buy a lottery ticket...
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 07-23-2020, 04:34 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
I recommend getting stainless steel replacement lines from someplace like inline tube, but they're more expensive. Well worth it though if you live in the rust belt.
After my car frames had been sandblasted, I painted them with a super good quality black metal primer and high-gloss black overcoat. They still look good after many decades of use.
My neighbor and I went to look at used trucks, as he was searching for one. Most of the trucks they had were 2004-2010 models (all chebbies except for one Ford F150). Every chebby had last rear frame crossmember nearly desintigrated and some even had the second to last crossmember gone from rustout. We saw one where someone had replaced the second to last crossmember with a piece of pipe. Almost all the frames were very rusty.
I have tried to replace rusty nuts and bolts under the car with stainless steel when doing service work.
Daves55Sedan is offline   Reply With Quote
Old 07-24-2020, 01:35 PM   #4
JimNNN
I'm glad I'm replacing all of the brake lines on my '65 T-Bird. However, I really need to replace all the lines on my early 60's Mercury, too. Way too many projects.
Thanks for posting the warning to remind us all what we need to prioritize. Glad you weren't hurt in the accident.
JimNNN is offline   Reply With Quote
