Old 05-14-2019, 09:33 PM   #1
Straightpipes
Straightpipes's Avatar
Default 34 Tudor roof information
I have a 34 2 door sedan that i am bringing back to life. It is missing all roof wood and brackets. I can buy the wood. Are the metal brackets available? If not, could I just use the long wood and assemble it without the brackets? Not worried about being correct. Thanks
Straightpipes is offline   Reply With Quote
Old 05-16-2019, 07:30 AM   #2
Pete/Ct.
Default Re: 34 Tudor roof information
You should be able to pick them up at Hershey. Stop over my spot RCK14 21 Ill explain. Pete/Ct.
Pete/Ct. is offline   Reply With Quote
Old 05-16-2019, 11:12 AM   #3
95476
95476's Avatar
Like these ?
How many do you need ?
One of my 2- dr's has 3 per side one has 4
My Victoria's have 4 per side.
95476 is offline   Reply With Quote
Old 07-14-2019, 09:27 PM   #4
Straightpipes
Bttt
Old 07-14-2019, 09:54 PM   #5
cas3
there are small brackets at the ends of each wood bow where the bolt goes thru, easy to make, if no one has a pic on file i'll take one tomorrow night after work. the wood bows basically match the contour of the roof shape, so you could make a template of cardboard at the rear, and another at the front. you will find the arch gets flatter as you get to the front. make em too big, and carve it to your eyeball's liken.
Old 07-14-2019, 10:51 PM   #6
rbone
I'm pretty sure I have some pictures of those brackets from when I replaced the headliner on my 34 Tudor a few years ago. I'll try to find them on my work computer tomorrow and post them.
rbone is offline   Reply With Quote
