Old 07-30-2020, 05:27 PM   #1
old john
Default 292 oil pump
I think the oil pump is leaking. can I replace gaskets, O ring as easy as it looks in the shop manual ? thanks John
old john is offline   Reply With Quote
Old 07-30-2020, 05:38 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 292 oil pump
The two gears will fall out, and maybe the drive shaft too.
Old 07-30-2020, 06:25 PM   #3
darrell
they will if your not careful.just work them back in if they do.
darrell is offline   Reply With Quote
Old 07-30-2020, 10:44 PM   #4
fordor41
fordor41's Avatar
I changed my oil pump O ring in the winter. I took some soft copper wire and looped it around the pump and when I removed the bottom plate I secured the pump gears in place. Set the O ring in place and loosed the wire enough to slide the bottom plate in place
fordor41 is offline   Reply With Quote
Old 07-31-2020, 10:54 AM   #5
old john
Thank you all try it soon.
Old 07-31-2020, 06:20 PM   #6
Ole Don
Ole Don's Avatar
While you are down there and all dirty anyway, remove the big nut next to the oil in tube. Check the spring inside, and make sure the sliding part is free and clean. You may want to add two flat washers under the spring to raise oil pressure.
Ole Don is offline   Reply With Quote
