12-06-2020, 10:55 AM | #1 |
What adhesive to glue windlace to metal frame?
What is best non-aerosol adhesive to glue windlace to metal frame?
Thanks for your time! Ivan |
12-06-2020, 11:15 AM | #2 |
Re: What adhesive to glue windlace to metal frame?
Any good contact cement. Do not use water based contact cement. I use Weldwood, 3-M and several others.
12-06-2020, 01:37 PM | #3 |
Which vehicle are you working on and what metal frames?
12-06-2020, 10:18 PM | #4 |
Thanks, pretty evident what I peeled off was old contact cement...
12-06-2020, 10:20 PM | #5 |
1930 Deluxe Coupe, hinge side of door frame.
12-07-2020, 08:56 PM | #6 |
Chris W. |
12-07-2020, 09:28 PM | #7 |
There should be a channel along the forward edge of the door that gets crimped to hold the windlace along the upper edge of the door alongside the window.
12-07-2020, 09:42 PM | #8 |
The channel has to be carefully pried open and cleaned out first. Somebody has punched extra holes in the passenger side door channel.
12-08-2020, 07:57 AM | #9 |
3M weather strip adhesive is what I used. It comes in a tube and is available in yellow or black. Works well for any application requiring a glue. The windlace is correct to be installed on the door side, not the hinge side. Looks as though someone used a chisel to secure the windlace in the past.
12-09-2020, 08:40 AM | #10 |
3M weather strip adhesive and Weldwood contact are both excellant.
Based on your pic i would use 3m because it is thicker. |
12-10-2020, 12:40 AM | #11 |
hi to all,
will this stuff also work for putting the webbing on the frame? if so what size bottle do i need? I see a 3 ounce size....sounds too little...tks, jerbo |
12-10-2020, 08:27 AM | #12 |
Jer, just get a quart of Weldwood, that will do it.
https://www.amazon.com/00272-Origina...7606813&sr=8-1 |
12-10-2020, 10:08 AM | #13 |
I use shoe-goo for nearly every kind of gluing need. It is thick, very strong, waterproof and stays flexible. I have used it for fabrics and holding mechanical items that need both strength and flexibility. For example, on my '31 a few dabs on the back of the ammeter and it is held in place firmly...on a dirt bike I have used it to re-attach a rubber mount that holds the exhaust pipe in place, a lot of vibration, heat and stress...and it held for years! Unbelievably versatile stuff I flat count on for all kinds of repairs and bonding.
