Old 12-06-2020, 10:55 AM   #1
ilangford
Question What adhesive to glue windlace to metal frame?
What is best non-aerosol adhesive to glue windlace to metal frame?
Thanks for your time!
Ivan
ilangford is offline   Reply With Quote
Old 12-06-2020, 11:15 AM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: What adhesive to glue windlace to metal frame?
Any good contact cement. Do not use water based contact cement. I use Weldwood, 3-M and several others.
Tacoma Bob is offline   Reply With Quote
Old 12-06-2020, 01:37 PM   #3
Gary Karr
Gary Karr's Avatar
Which vehicle are you working on and what metal frames?
Gary Karr is offline   Reply With Quote
Old 12-06-2020, 10:18 PM   #4
ilangford
Thanks, pretty evident what I peeled off was old contact cement...
Old 12-06-2020, 10:20 PM   #5
ilangford
1930 Deluxe Coupe, hinge side of door frame.
Old 12-07-2020, 08:56 PM   #6
CWPASADENA
CWPASADENA's Avatar
I thought the windlace at the front of the door opening was attached to the body hinge pillar and held in place by the kick panel, the ends of the dash rail and the windshield side garnish molding. I did not think it was glued to the door frame. This is the way my Tudor is and I thought the coupes were the same????
Chris W.
CWPASADENA is offline   Reply With Quote
Old 12-07-2020, 09:28 PM   #7
40-A Twins
40-A Twins's Avatar
There should be a channel along the forward edge of the door that gets crimped to hold the windlace along the upper edge of the door alongside the window.
40-A Twins is offline   Reply With Quote
Old 12-07-2020, 09:42 PM   #8
40-A Twins
40-A Twins's Avatar
The channel has to be carefully pried open and cleaned out first. Somebody has punched extra holes in the passenger side door channel.
Old 12-08-2020, 07:57 AM   #9
desotoguy
3M weather strip adhesive is what I used. It comes in a tube and is available in yellow or black. Works well for any application requiring a glue. The windlace is correct to be installed on the door side, not the hinge side. Looks as though someone used a chisel to secure the windlace in the past.
desotoguy is offline   Reply With Quote
Old 12-09-2020, 08:40 AM   #10
old31
3M weather strip adhesive and Weldwood contact are both excellant.
Based on your pic i would use 3m because it is thicker.
old31 is offline   Reply With Quote
Old 12-10-2020, 12:40 AM   #11
jerbo
hi to all,
will this stuff also work for putting the webbing on the frame? if so what size bottle do i need? I see a 3 ounce size....sounds too little...tks, jerbo
jerbo is offline   Reply With Quote
Old 12-10-2020, 08:27 AM   #12
old31
Jer, just get a quart of Weldwood, that will do it.
https://www.amazon.com/00272-Origina...7606813&sr=8-1
Old 12-10-2020, 10:08 AM   #13
kawagumby
kawagumby's Avatar
I use shoe-goo for nearly every kind of gluing need. It is thick, very strong, waterproof and stays flexible. I have used it for fabrics and holding mechanical items that need both strength and flexibility. For example, on my '31 a few dabs on the back of the ammeter and it is held in place firmly...on a dirt bike I have used it to re-attach a rubber mount that holds the exhaust pipe in place, a lot of vibration, heat and stress...and it held for years! Unbelievably versatile stuff I flat count on for all kinds of repairs and bonding.
kawagumby is offline   Reply With Quote
