05-21-2018, 06:41 PM | #1 |
Vacuum splice - late flathead - best access point
Later Ford flatheads have a threaded connectors/steel line connecting the distributor and 885 Holley carburetor.
For tuneup using vacuum gauge, I need to "T" into this vacuum line between carb and distributor. I've considered sawing the steel pipe midway and using rubber hose to do the "T" and when done, use rubber hose to put things back together. But sawing the line leaves a permanent scar. Surely there is a better or preferred way. What do you recommend here? |
05-21-2018, 07:20 PM | #2 |
Re: Vacuum splice - late flathead - best access point
The Mercury 885 carb vacuum line that is on the back of the carb. does not provide full manifold vacuum, it is a timed spark port to operate the loadomatic distributor.
Suggest you 'T' into the the line that provides vacuum to the wipers.
05-21-2018, 09:37 PM | #3 |
A agree with 51 Merc. Tie in to the line from the manifold to the wipers. The line from the carb is designed just for the loadamatic distributor.
05-21-2018, 10:01 PM | #4 |
As I recall, the line from carb. to dist. supplies venturi vacuum which is the opposite of manifold vacuum.
05-22-2018, 06:26 PM | #5 |
05-22-2018, 07:15 PM | #6 |
Manifold vacuum is used to check the health/tune of an engine. As stated above, the windshield wiper connection can be used for manifold vacuum tests. |
05-25-2018, 07:52 AM | #7 |
The venturi vacuum on the loadamatic system increases with engine rpms (from increased air velocity passing through the venturi).
This is (generally) the opposite of manifold vacuum which decreases with throttle opening. The diaphragm on the loadamatic distributor functions opposite of most vacuum advances. |
05-27-2018, 02:15 PM | #8 |
I just read a bulletin which advocated the mechanic to cut a spare vacuum tube and insert a "T" for the gauge. I don't have access to a spare vacuum tube and won't cut my existing tube. Guess the only alternative is removing the tube and fashioning a new one. I suppose the fittings are obtainable. I don't imagine the flare (single/double) is critical.
05-27-2018, 05:02 PM | #9 |
Could possibly make up a copper or steel line using the components as shown to fit the carb and distributor.
05-27-2018, 06:23 PM | #10 |
Aren't "brake line fittings" (flare fittings) different from compression fittings (used with the sleeve)?
05-27-2018, 06:36 PM | #11 |
The 'nut' has a 45° chamfer that will compress the ferrule and is the correct straight thread to fit the carb and dist. It is the only component that is used.
05-27-2018, 06:58 PM | #12 |
Might work. I'd still use the proper "Ford Nut" though.
05-27-2018, 07:25 PM | #13 |
I used this method years ago when I didn't care to search for a "Ford Nut".
Worked well until carb. and dist. were swapped for better options.
05-27-2018, 08:23 PM | #14 |
I know what you mean; the last time I needed one, I couldn't find one and had to come on here and beg. "JWL" came through for me though.
