11-02-2023, 12:54 PM | #21 |
Re: Vacuum wiper ,fuel pump Questions
Its 223 6 cylinder
11-03-2023, 05:05 AM | #22 |
I can't find a decent photo. If you have a combination pump. the pump itself is on the PS of the engine and the intake manifold on the DS of the engine. The plumbing is complicated.
If no one here comes up with a photo, I will go down to my 'COBWEB CORNER' and look through the 1955 WSM. |
11-03-2023, 07:21 AM | #23 |
Thanks for your help
11-03-2023, 07:33 AM | #24 |
Ain't no problem as I learn also ...
11-05-2023, 10:08 AM | #25 |
On hooking up the fuel pump vacuum lines if I go from the line to the intake and the other to the wiper it should work?
11-05-2023, 10:57 AM | #26 | |
I was trying to find a good photo but cannot. I still need to check the WSM to see if there is a good install ILL ... The will be four steel lines - FUEL LINE - MANIFOLD VACUUM SOURCE LINE - VACUUM MOTOR LINE TO MOTOR - LOAD-O-MATIC LINE FROM CAR TO DIST - See if these photos show large enough - ADDENDUM - Well, I have some old photos of the system but for some reason this system will not upload them.
***** - MULTI-VEHICLE SYNTHETIC TRANSMISSION FLUID - Multi-vehicle transmission fluids are becoming more and more popular in the marketplace. Oil marketers design these fluids for a wide range of automatic transmission types. While they are not licensed by any specific auto manufacturer ... ??? ... enough said ... DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
11-05-2023, 11:51 AM | #27 |
11-05-2023, 01:51 PM | #28 |
Thanks for the pictures It all makes sense now
11-05-2023, 05:41 PM | #29 |
I was hoping to do better. The MPC doesn't show a detailed engineering drawing of the install(s). I haven't opened the WSM yet but also doubt it goes into detail.
It is the same design just split because FORD put the components on differing sides of the engine for the I-223 SERIES,
