09-03-2016, 08:20 PM | #1 |
No oil pressure
Recently installed a freshened up early Canadian flathead. Ran a mechanical gauge to where the original mushroom type electronic oil sending switch would have been installed and plugged the other 2 oil line outlets Canadian blocks have. This block has not been modified for the full flow system. Checked oil pressure after starting and zero. Shut her down!Removed line from rear of mechanical gauge and briefly restarted to see if gauge faulty? No oil shooting out? Shut her back down! Wondered if I may need to have mechanical gauge hooked to one of the other 2 oil outlets on bell housing. Well hoping really. Not touching again until I hear from some of the you gurus. Hope I haven't already damaged something. Appreciate any advice you guys might be willing to share. As always "thanks"!
09-03-2016, 08:25 PM | #2 |
Re: No oil pressure
Did you 'prime' the oil pump?....
09-03-2016, 08:50 PM | #3 |
Re: No oil pressure
^ That would be my first thought. Disconnect power from the engine ignition, remove the spark plugs. Remove the fitting for the pressure gauge and pour a cup of oil down the hole. Leave the hole open and crank the engine (12v is best). Watch the open port for oil.
The port the gauge is connected to has nothing to do with it. |
09-03-2016, 08:55 PM | #4 |
Re: No oil pressure
All of the ports are connected, so one is the same as another pressure wise.
09-03-2016, 10:35 PM | #5 |
Re: No oil pressure
hmmm...methinks you might have the 95% oil setup on your block....you have 3 holes at the back of the block??....might be military block which used the 95% filtering setup...just a thought.....check horizontal passage for a plug....until you figure it out, don't run the engine....good luck....Mike
09-04-2016, 02:54 AM | #6 |
Re: No oil pressure
The pump should be delivering oil from one of the holes if it is cranked over with all those holes unplugged. If not oil needs to be pushed down into the pump before anything else happens. Once oil will come back up by pump action (after priming) then move on to checking as Mike has suggested. The plug he is talking about, would be in the horizontal bore and requires an external loop from one of the bottom holes (horizontal or vertical) to the upper hole, as in a full flow filter or oil cooler loop. Otherwise the plug would need to be removed and the top hole and a bottom hole plugged. I do not wish to complicate this, but usually the Canadian engines don't have a horizontal plug because they cleverly cause the diversion with the fitting in the top hole. Last edited by Bluebell; 09-04-2016 at 03:00 AM. |
09-04-2016, 07:11 AM | #7 |
Re: No oil pressure
This one does have the 3 outlet holes. Horizontal. then the vertical for oil pressure sending unit then the top one in the bell housing. Sound like I need to either remove the plug from the horizontal (bottom) outlet or run a line from it to the top outlet in the bell housing (correct)? If I can get to the plug in the inside the vertical (bottom) outlet is it hex , carriage or screw head. Again thanks again everyone who has taken time to reply!
09-04-2016, 09:01 AM | #8 |
Re: No oil pressure
09-04-2016, 09:22 AM | #9 |
Re: No oil pressure
The presence or absence of the grub screw would not effect the presence of oil pressure coming from the oil pump if all of the passages were open (plugs removed). It is a little unclear from your first post which passage you had your gauge plumbed into. On the diagram KGS posted if it is the two on the left, they are connected directly to the oil pump. If it is the one a little to the right and it has been modified for a 95% setup (you stated it had not) then you would not see oil pressure.
Need to figure out what you have. Prime the oil pump, then crank the engine with the spark plugs out and all of the oil passage plugs removed and see if you have oil. If so, plug the two on the left (in KGSs diagram) and check it again and see if you get oil pressure on the opening to the right. If not, it has been modified for a 95% filtration system. At that point either setup the rest of the 95% system or remove the grub. Last edited by JSeery; 09-04-2016 at 09:27 AM. |
09-04-2016, 09:30 AM | #10 |
Re: No oil pressure
All I can add is that, on my '51 Merc that had been sitting for over 20 years, it took an agonizingly long time for it to build pressure the first time I fired it. This was after I had primed the oil pump. Looking back, it was probably about 20-30 seconds, but it seemed like an eternity then. Now, it idles at 25 lbs and holds 45 lbs at 2000 rpm. How long did you crank it?
09-04-2016, 09:39 AM | #11 |
Re: No oil pressure
If it happened to be one of the Canadian modifications then it is a little different. Only the top fitting on the left (on the diagram) would have oil pressure IF the special fitting is still in place. In this case with the cranking test again there would be oil pressure on the left top plug opening but not the ones on the side or the one over to the right. If that is the case, just remove the fitting that blocks the other passageways.
Note: I really don't believe the fitting can remain in the block if the rest of the filtration system is removed, but if all else fails to pan out might be worth checking out. You should be able to see the sleeve blocking the passage by looking in the side passage opening if it was there. Last edited by JSeery; 09-04-2016 at 02:17 PM. |
09-04-2016, 09:49 AM | #12 | |
Re: No oil pressure
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 09-04-2016 at 09:56 AM. |
09-04-2016, 10:15 AM | #13 |
Re: No oil pressure
09-04-2016, 11:23 AM | #14 |
Re: No oil pressure
Thanks guys. I figured this new engine had these 3 holes from the factory? I didn't have it machined to have the 95% oil filtering system but maybe Ford did? I just know it has 3 holes where the original engine that came out only had 2 and the oil sensor switch was hooked to the top one and the bottom was plugged, again (That is on the original engine). The center outlet where the electronic oil sending switch would have been originally located is the passage I have my mechanical gauge plumbed into on the new Canadian engine. I have plugged the oil outlet and inlet holes, 1 above and 1 below. I will remove mechanical gauge hookup from the block (center or horizontal hole) and pour more oil down it and remove the plugs from the oil outlet and inlet holes then remove spark plugs and spin over and see what happens. Sounds like I definitely need to remove grub screw if I not running a filter? Much obliged fellas!
09-04-2016, 11:29 AM | #15 |
Re: No oil pressure
Ford would not have installed the grub. It is fairly easy to check and see if there is anything in the passage way. Insert a punch or something and see how far in it goes. I'll post a photo of it. If it has the Canadian Ford modification it would have a sleeve on a fitting going down into the port from the top fitting.
Note: Just went an measured a block. With the grub it is about 1.3 inches deep, without the grub it should be about 3.0 inches deep. Last edited by JSeery; 09-04-2016 at 02:17 PM. |
09-04-2016, 12:56 PM | #16 | |
Re: No oil pressure
Sounds like I definitely need to remove grub screw if I not running a filter? Much obliged fellas! You state in your first post it has not been machined to 95% flow and in your above statement you state you need to remove grub screw??? If there is a screw in there it has been converted for filtration purposes. Two conflicting statements. Remove the horizontal passage plug and see how deep the hole is with a 6" coat hanger wire and you are done.It will hit a grub if one is installed.If no screw discovered then your troubles are somewhere else.Who assembled the engine. R |
09-04-2016, 01:29 PM | #17 | |
Re: No oil pressure
09-04-2016, 04:16 PM | #18 |
Re: No oil pressure
The Canadians built 28,000 Universal (bren) carriers with this factory set up.(The British built 50,000)The majority of them ran just an oil cooler. Later they ran the oil cooler and a full flow filter off this system. A number of the Canadian military pattern trucks ran full flow filters from this port arrangement. None of then had a plug in the horizontal gallery because the top fitting had an extention tube that basically blocked off the horizontal bore. When the Australians Built their 8000 carriers they used a standard fitting, but plugged the horizontal bore. I have not seen the Australian plug, but am told it is a restrictor with a hole through it.
I have 3 sets of the long Canadian fittings and the Bypass valve for the oil coolers. I am into carriers. |
09-04-2016, 04:29 PM | #19 |
Re: No oil pressure
My guess is the holes for the cam bearing are not lined up.
09-04-2016, 06:18 PM | #20 |
Re: No oil pressure
