Old 10-24-2023, 06:31 PM   #21
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Easier steering for ‘35 Tudor?
Originally Posted by cas3 View Post
That looks like street rod parts to me, I think keeping all bolt on Ford parts a way better move. Looks stock, but drives mo better.
The only STREET ROD-ish looking part required would be the steering box adapter plate seen BELOW, available from 'Chassis Engineering'.
Click Links Below __
T5 W/TORQUE TUBE
Old 10-24-2023, 06:36 PM   #22
V8COOPMAN
V8COOPMAN's Avatar
The only STREET ROD-ish looking part required would be the steering box adapter plate seen BELOW, available from 'Chassis Engineering'. This bolts to your EXISTING '35 frame mount plate. Then the "525" steering box bolts to the adapter plate. 75% of the people walking by your car won't have a clue that your steering box is not a Ford piece. And the steering gets no better than this modern box has to offer, period!
Coop
T5 W/TORQUE TUBE
Old 10-24-2023, 07:37 PM   #23
cas3
Mounting the box is child's play, but how to get rid of the rag joint and get back to a Ford column and shaft, much less have a proper light switch, would take some sypheren
Old 11-04-2023, 11:26 AM   #24
AnthonyG
AnthonyG's Avatar
Originally Posted by V8COOPMAN View Post
Using the '37-'39 allows the use of the steering wheel headlight switch just like in your '35, as the '39 was the last year to incorporate that feature.
Coop
It sounds like using the ‘37-‘39’ S Box while I can use the ‘35 steering wheel I’ll need a,:
- ‘37-‘39 column
- ‘37-‘39 S Box
- conversion mount bracket
Is that all the parts?
Thx
Nomad
AnthonyG is offline   Reply With Quote
Old 11-04-2023, 07:44 PM   #25
BobR35
BobR35's Avatar
- ‘37-‘39 column
- ‘37-‘39 S Box
Thx
watching
BobR35 is offline   Reply With Quote
Old 11-05-2023, 07:31 AM   #26
AnthonyG
AnthonyG's Avatar
Question Re: Easier steering for ‘35 Tudor?
Do I have this correct?
- ‘37-‘39 column
- ‘37-‘39 S Box
Thx
Nomad
Old 11-05-2023, 07:35 AM   #27
AnthonyG
AnthonyG's Avatar
I know I’ll be getting a lot of rhetoric back from this. But I gotta ask a question beings I am incapacitated and might be for the rest of my life with my back. My question is doing the switch to either power steering or going to the 1939 Ford steering box, does it make more sense to considering the labor simplicity to have someone do it to go to a mustang two conversion kit front end. I’ll get a Power rack and pinion steering, a much nicer ride and more modern handling. While I know the kit is much more expensive but It makes the installation much more straightforward & many shops can do! I’m thinking between not being able to do myself, drive easability for my back & the labor the kit may be the better way to go in the long run for me? Rather than trying to go with the Saginaw power steering or the 1939 Ford steering box conversion!
I know there will be a lot of conversation, probably more negative and positive,
But that’s OK, more info, always better than less. But please give me your thoughts.
T
Nomad
Old 11-05-2023, 03:00 PM   #28
FlatheadTed
FlatheadTed's Avatar
!935 to 39 column shaft is 47" you only need to drill one hole in the box ,you can see that hole on the Coup post 7 third picture down were someone has drilled it .The Mustang two swap others may advice .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-05-2023, 03:14 PM   #29
AnthonyG
AnthonyG's Avatar
Do I need the ‘39 shaft or can I use the ‘35 shaft?
Nomad
Old 11-05-2023, 03:22 PM   #30
AnthonyG
AnthonyG's Avatar
Let me be more specific! Can I use my ‘35 steering column w the ‘39 steering box? Can I simply modify the ‘39 box mount holes to bolt to existing frame mounting hardware?
Nomad
Old 11-05-2023, 03:27 PM   #31
FlatheadTed
you can use either ,but the 39 shaft will place the locking colour differently but can be drilled
Old 11-05-2023, 03:39 PM   #32
AnthonyG
AnthonyG's Avatar
[QUOTE=FlatheadTed;2267593]you can use either ,but the 39 shaft will place the locking colour differently but can be drilled[/QUOTE
I’m not trying to be obstanant but why would I use a ‘39 colum if I already have the stock ‘35 column? What am I missing Ted ?
Nomad
Old 11-05-2023, 07:04 PM   #33
FlatheadTed
In post 20 I explain how to drill the box .Its much harder to remove the 35 shaft when 39 boxes come with a 39 shaft . The word should be locking collar that's inside .Not Column lock mechanism /colum drop .
Old 11-10-2023, 01:07 PM   #34
AnthonyG
AnthonyG's Avatar
Ted, does the ‘35 steering wheel fit on the ‘39 column?
Nomad
Old 11-10-2023, 02:19 PM   #35
FlatheadTed
Yes .Also make sure you fit a new seal on the sector ,
Old 11-11-2023, 06:52 AM   #36
AnthonyG
AnthonyG's Avatar
Ted where is the seal on the sector? Don’t think I know what that is?
Nomad
Old 11-11-2023, 05:17 PM   #37
V8COOPMAN
V8COOPMAN's Avatar
Anthony ..... The SECTOR is the main DRIVEN, splined shaft that the Pitman arm affixes to. There is normally a seal toward the bottom of the steering box to contain the lubricant. This leaky seal is why we all have turned to John Deere Corn Head grease as a 'fix'! The seal would likely be located just above the splines in this gearbox.
T5 W/TORQUE TUBE
