Old 07-26-2023, 07:11 PM   #21
Bored&Stroked
Bored&Stroked's Avatar
Default Re: S10 T5 into a 41 truck
Thanks Krylon . . . any idea on the actual dimensions on the input - from the front of the transmission? It might help folks find transmissions to use your kits - which is good for everybody.
Old 07-26-2023, 07:14 PM   #22
Krylon32
Approximately 7.25
Krylon32 is offline   Reply With Quote
Old 07-30-2023, 02:47 PM   #23
AnthonyG
AnthonyG's Avatar
Originally Posted by Krylon32 View Post
Interesting reading the suggestions and comments. This conversion to a T5 is so simple and works so good almost anyone with a degree of mechanical skills can do it. I know some of you Poo Poo the S10 T5 but most of the many 100's of my customers that have used them have very few complaints. My kit supplies all the early Ford style parts needed and will hook to the stock clutch linkage. You can use your stock PP with a new disc supplied by Fort Wayne Clutch. Personally I like the 35-40 center X member kit that 40ragtopdown over on the HAMB makes. It is reasonably priced, includes the wishbone brackets and has a good fit. The open drive conversion supplied by Hot Rod Works is well engineered, fits, and it along with the wishbone kit and torque arm works great. The other alternative for the rear is a CE or TCI parallel rear spring kit and a later rear end. This set up is a little more expensive but works good. I expect some negative feedback on my comments but I've been doing T5 conversions for almost 30 years so am speaking from a few experiences.
Hi Krylon32, sounds like ur kit is neat! How much & what’s included? Sounds like not the adaption plate to mount the T5 nor the wishbone balls? I have sent 40ragtopdown a conversation on the Hamb on his 35-40 X-Member conversion JIC?
Best Tony
Nomad
AnthonyG is offline   Reply With Quote
Old 07-30-2023, 04:14 PM   #24
Krylon32
Check my ad in the 4 sale section for a list of what's included and the price. I have them in stock for the 85-92 and 93 up S10 T5 trans. My kit has everything but the clutch disc.
Old 07-30-2023, 07:54 PM   #25
V8COOPMAN
V8COOPMAN's Avatar
Gary ..... I believe Tony is asking about a crossmember similar to that pictured BELOW which accepts split wishbone ends/trans mount. I don't see one listed in your kit.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 07-30-2023, 08:36 PM   #26
Krylon32
I don't sell those products. That's why I sent him to 40ragtopdown on the HAMB
Old 07-31-2023, 10:09 AM   #27
38bill
38bill's Avatar
This is the Hot Rod Works mount. This is the type that didn't work for my application. I had to make one were the Heim joint was vertical rather than horizontal like these mounts. If someone wants one I'm pretty sure I still have the one I didn't use.
38bill is offline   Reply With Quote
Old 07-31-2023, 10:44 AM   #28
petehoovie
petehoovie's Avatar
Old 07-31-2023, 02:30 PM   #29
V8COOPMAN
V8COOPMAN's Avatar
That one is for the REAR radius rods. The one Tony was asking about is for the FRONT wishbone and also serves as a transmission mount.
Coop
T5 W/TORQUE TUBE
Old 07-31-2023, 03:19 PM   #30
38bill
38bill's Avatar
There are kits sold that are made to replace the entire center section of the frame. Speedway Motors shows them (TCI Engineering 204-2073-00 TH350 Transmission Mount-1937-1940 Ford). I have never seen a bolt in kit that is made for the ball end of the wishbone. You could purchase the kits with or without the flanges for the split wishbone so I ordered the one without the split bones mounts and built my own ball mount. It's basically the same idea as shown in the video above.
Old 07-31-2023, 03:36 PM   #31
Krylon32
The picture above is what 40ragtopdown over on the HAMB manufactures. It is a great quaslity product and about half the price of a TCI or CE kit. This installation seems to work best with split bones. I have had a few customers do the kit with a spacer to lower the bones for clearance, I have no idea what they did to clearance the center of the x for the T5. I've used the yellow Hot Rod Works piece for the rear bones with no problems.
Old 08-07-2023, 06:08 AM   #32
AnthonyG
AnthonyG's Avatar
Thx for all the info guys, I went to 40ragtopdown on the Hamb. He’s got the kit & also showed some pics of a guy who modified his to accept the unsplit wishbone w ball mounted similarly to the YouTube video In the original post in the thread.
Nomad
Old 08-07-2023, 11:03 AM   #33
petehoovie
petehoovie's Avatar
