01-22-2021, 09:00 AM | #1 |
Advice on restoring hub caps
Anyone restored Mercury/Ford caps of this type?? I heard about drilling the hole in back side of shell and using compressed air to "pop" the SS cap off the shell. SO my questions are:
1) What size hole did you drill?? I would imagine around an 1/8, 3/16th maybe??? 2) The biggest question of them all, what method did you use to get the caps back on the shell??? Thanks Rockfla |
01-22-2021, 09:16 AM | #2 |
Re: Advice on restoring hub caps
I'm confused as usual.?. Why not just buff the stainless and paint the surround ? Then
use a paint pin for lettering. And second I would not use a twist drill. If you must separate the parts buy a end mill used on milling machines, it will make a flat hole not a V hole..thats what I would do......sam |
01-22-2021, 09:28 AM | #3 | |
01-22-2021, 09:30 AM | #4 |
Rockfla, here is the link to a step-by-step procedure to restore these hubcaps. Hope this helps out.
https://www.fordbarn.com/forum/showt...ghlight=hubcap |
01-22-2021, 09:38 AM | #5 | |
IF any interest, I will document my project and post pictures AGAIN if any interest!!! |
01-22-2021, 10:19 AM | #6 |
01-22-2021, 10:26 AM | #7 |
Thanks Bruce for sharing the information on your techniques for disassembling and reassembling these caps. It is a project I plan to tackle in the future.
01-22-2021, 10:40 AM | #8 |
01-22-2021, 02:21 PM | #9 |
Hello, i have restored several of that type of hubcap, to remove the S.S. skin (approx. 0.012" thick) i use a #60 drill bit and just pierce the carbon steel cap, apply high pressure air and the outer skin usually pops off. To re-install the outer cap, place the carbon steel cap in the freezer overnight and heat the S.S. cap to 250*, and the outer cap will slide right on.
Tom |
01-22-2021, 02:25 PM | #10 |
Tried to post images, no luck.
Tom |
01-22-2021, 02:36 PM | #11 | |
01-22-2021, 02:37 PM | #12 |
Images, maybe.
01-23-2021, 02:36 PM | #13 | |
Thanks for posting the link, Greegger
When you turn on your car, does it return the favour? |
01-23-2021, 06:40 PM | #14 |
Added for hotcoupe
01-23-2021, 07:03 PM | #15 |
I tried the air method blowing through a small hole & had 1 pop off out 5 I tried.
01-24-2021, 12:21 AM | #16 |
Those 1939 Ford Mercury are very rare hubcaps. |
01-25-2021, 07:59 AM | #17 |
01-25-2021, 07:59 AM | #18 |
01-25-2021, 09:05 AM | #19 |
Make sure that your blower attachment has the rubber tip. That makes sure you seal the drilled hole and get the direct pressure of the air.
And you shouldnt need a lot of air pressure -- usually 20 lbs works. |
