Old 01-12-2021, 06:31 PM   #1
Branded
Branded's Avatar
Default Water Pump
Ok, I have a problem. I’m a pack rat and need to clean out a few items. Do the original water pumps from my 40 V8 have any monetary value or are they just good for door stops. I have problems throwing anything away.
Branded is offline   Reply With Quote
Old 01-12-2021, 06:37 PM   #2
Talkwrench
Talkwrench's Avatar
Default Re: Water Pump
If the ones you have in have been there a while send your cores to Skip and have them rebuilt, replace them.. Just a thought .
Old 01-12-2021, 07:30 PM   #3
Kube
Kube's Avatar
In other words - core value? Very little to zero value.
I have listed a number of them (six) on eBay for $1 for all six. All shipped within a large flat rate box. NO takers for $1.
I ended up tossing them along with a dozen or so earlier ones.
Kube is online now   Reply With Quote
Old 01-12-2021, 07:43 PM   #4
mcgarrett
I know what you mean about being a pack rat and tossing anything that looks like a vintage Ford part. I installed a pair of new pumps from Speedway a couple of years ago and can forget about water pump problems. Skip Haney is also a good source for rebuilt, but in the end you still have "rebuilt" pumps. When you compare acquisition cost, the new ones are far superior to anything rebuilt. By the way, to prove how hard it was to let go, I just scrapped 20 flathead water pumps 2 months ago that I had been holding on to for 25 years!!
Old 01-12-2021, 08:34 PM   #5
Branded
Branded's Avatar
You all just helped me with my decision, looks like time to scrap these things.
Old 01-12-2021, 09:00 PM   #6
Kube
Kube's Avatar
I believe we must all, myself included, realize this hobby is not becoming more popular folks interested and more parts becoming available, values decrease. Simple law of economics.
I feel bad when trashing stuff more so as it is all a part of history - not necessarily any monetary value.
Old 01-13-2021, 03:29 AM   #7
Dave Slater
Dave Slater's Avatar
Ring Skip and see if he wants cores rather than just throw them out
Dave Slater is offline   Reply With Quote
Old 01-13-2021, 05:45 AM   #8
DavidG
DavidG's Avatar
Mike,
Please do not throw away any original '32-34 water pumps or original '35 or '36 right side pumps.
Old 01-13-2021, 08:43 AM   #9
rockfla
rockfla's Avatar
Originally Posted by DavidG View Post
Mike,
I second this statement.......I will pay you a fair price for them.....Especially 35's (for me). OR anyone else who is thinking of scraping them for that matter!!!!
rockfla is online now   Reply With Quote
Old 01-13-2021, 08:48 AM   #10
Branded
Branded's Avatar
These are from a 1940 engine
Old 01-13-2021, 09:14 AM   #11
Rodrelic
I like to use temp gauges on both sides so I save any head mounted pumps. I am using one now that I drilled and brazed on a collar to get a sender in. Cooler to use 2 right side, greasable
Rodrelic is offline   Reply With Quote
Old 01-13-2021, 11:09 AM   #12
mcgarrett
Just to clarify my comments, I don't toss any head mounted water pumps! They definitely are kept and recycled i.e., they can even be re-used on Model A's with slight modifications.
Old 01-13-2021, 11:28 AM   #13
Terry,OH
Terry,OH's Avatar
Look to the difference between original and aftermarket pulleys and pump body. Unusual early (21 stud) pump RH body with heater hose connections cast into the body. Make sure you know what your going to trash.
Old 01-13-2021, 06:47 PM   #14
Rodrelic
Didn’t know that about model A, recently acquired one (A) motor and
May see what parts I can throw together to use it for a flivver
Old 01-13-2021, 07:22 PM   #15
Rodrelic
DidnÂ’t know that about model A, recently acquired one (A) motor and
May see what parts I can throw together to use it for a flivver. If it fits
Cool use it
Old 01-14-2021, 01:56 PM   #16
FritzJr
FritzJr's Avatar
Don't throw away any of the 79-8501 or 79-8502 dual pulley pumps. These are for '37 through '48 trucks and have bearings instead of bushings. They are sought after by folks who want to mount a supercharger on their flathead.
FritzJr is offline   Reply With Quote
Old 01-16-2021, 11:10 AM   #17
hop up
hop up's Avatar
So what year would be this water pump?
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 01-16-2021, 01:02 PM   #18
JM 35 Sedan
JM 35 Sedan's Avatar
Based on your picture, that appears to be a left side '36 Ford water pump. If it's an original '36 pump, it will have a 68-xxxx part number cast into one side. If someone is doing a high point restoration on their 36 Ford, it might be important to them to get that pump as a rebuildable core.
If/when I'm judging cars at an Early Ford V-8 Club Meet, for say a Dearborn Award, I look for the original part number on water pumps. If there is no part number, points are deducted. I've personally sold many original '32 to '53 water pumps as rebuildable cores.....and personally, I'd give original ford parts away before I would consider trashing them.
John
Old 01-16-2021, 01:11 PM   #19
JM 35 Sedan
Those pumps will fit from '37 to '48 flathead engines.
John
Old 01-16-2021, 01:13 PM   #20
JM 35 Sedan
Great suggestion!!
John
