Old 01-08-2020, 09:14 PM   #1
Afordman31
Afordman31's Avatar
Default Conventional oil and Synthetic oil
Been using 10W-30W Valvoline conventional oil in my Model A...finding out from the internet that it is being phased out.
I also read that the manufactures of new cars are recommending synthetic oils. Is it going to make a difference in the older cars?...checked oil tonight and some of the bottles of synthetic oil say recommended for vehicles with over 75,000 miles.
Appreciate your feedback.
Afordman31 is offline   Reply With Quote
Old 01-08-2020, 09:16 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Conventional oil and Synthetic oil
I don't think your Model A will notice a difference. Your hip pocket might though!
Old 01-08-2020, 09:34 PM   #3
Gary WA
Gary WA's Avatar
stick with what you have been using. Just change brands. all the same conventional oils.
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 01-08-2020, 09:41 PM   #4
mhsprecher
mhsprecher's Avatar
I use Mobil 1 in my Model A's, like I use in everything I have. Probably an unnecessary expense, but it's a better oil, so why not?
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 01-09-2020, 07:40 AM   #5
Flyboy1st
Thumbs up Re: Conventional oil and Synthetic oil
Synthetic oil has no equal in any engine. I have been working on aircraft in the Air Force for 37 years and there are no conventional oils used anywhere except maybe oiling access panel hinges if that is all that is available at the time. Had on old 1948 Harley that I used synthetic in and you couldn't find any sludge or wear after years of use, if you want to test the limits on oil it would be one of these old air cooled engines.
Flyboy1st is offline   Reply With Quote
Old 01-09-2020, 08:41 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
I run synthetic blends and 100% synthetic oils in both of my Model "A" cars, and have been doing so for thousands of miles. Synthetic oil does make a difference in the Model "A" engine. Less wear!
I change the oil once a year regardless of mileage.
Bob Bidonde
Old 01-09-2020, 01:23 PM   #7
Beater
Beater's Avatar
I do prity much the same thing. 15-40 syn oil in mine change oil in the spring
Beater is offline   Reply With Quote
Old 01-10-2020, 03:04 PM   #8
ronn
5 QUARTS OF SYNTHETIC AT WALMART IS NOW 14.88
I ONLY RUN SYNTHETIC IN EVERYTHING-EVEN MY RIDING MOWER. IT DOESNT BREAK DOWN LIKE REG OIL
Old 01-10-2020, 03:27 PM   #9
40 Deluxe
But, does "regular" oil really "break down"? If so, under what conditions?
Old 01-10-2020, 05:04 PM   #10
Synchro909
Synchro909's Avatar
I just checked: Synthetic oils in a deal with a filter included are on special at nearly $70 for 4 litres. I don't know of anybody who uses it and I don't wonder why.
Old 01-10-2020, 05:09 PM   #11
ronn
Ive used reg oil for years and at 3k miles, it is black as coal- from breaking down.
the synthetic will go 10k miles and look almost new. Noe obviously, if you dont have a filter, you wont get 10k miles out of your synth oil.
But my wifes honda synth oil looks terrific at 10k miles and I reuse the oil in my A's.
considering it is about the same price as reg oil here in the US- its a no brainer.
Yeah, you aussies have to pay to import everything. that does suck.
Old 01-10-2020, 05:22 PM   #12
xelhan
I found this on the net some years ago - very interesting
xelhan is offline   Reply With Quote
Old 01-11-2020, 08:42 AM   #13
fuzes45
Oil for vehicles over 75000 miles has additive to slightly swell seals to help prevent leakage.
Bob
fuzes45 is offline   Reply With Quote
Old 01-11-2020, 08:48 AM   #14
Jacksonlll
Jacksonlll's Avatar
Whatever you use, be sure to change it often. Keep clean oil in there. If the cost makes you keep it in there too long, don’t use it.
Old 01-11-2020, 09:53 AM   #15
Bob Bidonde
I made a mistake using synthetic oil too soon in a recently rebuilt engine. The rings did not seat as soon as they should have, so I went back to conventional motor oil for 500 miles. I am now running Mobil 1 which is a synthetic blend.
The principal advantages of synthetic oil are:
> Less additives to wear out increasing the oil's service interval;
> Less additives so lower cost. 5 quarts of full synthetic can be had for about $18. Blends cost more because of their conventional oil content & additional processing, but they are still price competitive with conventional oil;
> Higher temperature operating range;
> Reduces friction & wear significantly.
Bob Bidonde
Old 01-11-2020, 10:29 AM   #16
xelhan
Bob you forgot 40% increased oil film strength - it's like having another half bearing extra. Also, it doesn't age like mineral oil - you can go by driving distance and disregard time gone by.
