Old 02-08-2018, 03:00 PM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default Tdc #1 heads off?
Am adjusting valves and thought I would go through them a second time before I put the heads back on, as soon as I checked the valves on #1 I discovered the adjustment was way off. I understand the cam runs at half speed so why are the intake and exhaust valves both on their seats and piston at TDC #1 whenever I turn the the crank to TDC #1 as marked on my pulley? I know everything is working as it should because every time I come around to TDC #1 the gap on the valves changes. What should I also look for to confirm TDC on compression cycle?
36tudordeluxe is offline   Reply With Quote
Old 02-08-2018, 03:04 PM   #2
flatjack9
flatjack9's Avatar
Default Re: Tdc #1 heads off?
At TDC on the firing stroke, both valves are closed. You need to make two revolutions of the crankshaft to get back to the same condition
flatjack9 is online now   Reply With Quote
Old 02-08-2018, 03:32 PM   #3
BillM
BillM's Avatar
After the intake opens and then closes you are on the compression/firing stroke.
My web page:
http://myplace.frontier.com/~wgmumaw/
BillM is offline   Reply With Quote
Old 02-08-2018, 03:39 PM   #4
36tudordeluxe
That's what I needed to know, thank you.
Old 02-08-2018, 03:41 PM   #5
George/Maine
George/Maine's Avatar
There probably is a better right up.
Watch the intake open turn to TDC both valves closed, now adjust #1 ,
Then turn 90 degs and do next cylinder by firing order.
The intake will be just opening the next TDC is compression stroke.
George/Maine is offline   Reply With Quote
Old 02-08-2018, 03:47 PM   #6
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Put a steel strap across the cylinder with a bolt in the center to hit the piston. Turn engine by hand in one direction until the piston stops rotation and mark pulley location, then turn engine the other way until piston hits and mark pulley again. TDC is exactly middle of the two marks ......the most exact method geting or finding exact TDC..
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 02-08-2018, 04:03 PM   #7
Ol' Ron
Ol' Ron's Avatar
After the compression stroke the next time the piston is at TDC BOTH valves are open. This is called "split overlap" and is a good way to check if the cam is in right.
