Old 03-03-2021, 01:05 PM   #1
ChadCurrent
Default Finally running after 50 years
I have been busy but finally had time to get it running.
Thanks again for the parts that were given to me.
https://youtube.com/shorts/qHOJLEAFIfM
Need suggestions on what to use to connect my edelbrock carburetor to the bellcrank as I can't seem to find anything local.
I tried using an old throttle rod but it was too short and would get stuck.
Any suggestions? If you have links I'd appreciate it, I'm horrible at searching for things I'm not used to working on.
ChadCurrent is offline   Reply With Quote
Old 03-03-2021, 06:41 PM   #2
Ford56
Ford56's Avatar
Default Re: Finally running after 50 years
Sounds and looks great.
Ford56 is offline   Reply With Quote
Old 03-03-2021, 06:57 PM   #3
Gene F
Gene F's Avatar
You have the most important part of that throttle aparatus. The little ball studs are avaialble at Snyders. Part number a-9743. The rods...can't help ya with that one. Try that wrecking yard in AZ that advertizes in HMN. Or try Hills Restorations in Racine , Ohio.
Old 03-03-2021, 06:58 PM   #4
Gene F
Gene F's Avatar
I think there are 2 springs on that thing too. Macs, or Concourse Parts
Old 03-03-2021, 08:32 PM   #5
miker98038
miker98038's Avatar
Lookin good. Glad to see the progress. Someone on here (likely K) will have the exploded diagram for the linkage. From that you'll get a part number. Many years ago I replaced the teapot on my 55 manual trans car with a 1406 Edelbrock. I don't remember the specifics, but if got a pile of old throttle pieces, bellcrank, heim joints, etc. I probably used whatever was handy out of that box.
If you're using the large hole at the top, there's a bushing/washer for it. Might find it at a parts store, or the Edelbrock site.
miker98038 is offline   Reply With Quote
Old 03-03-2021, 09:20 PM   #6
scicala
scicala's Avatar
Don't use the large hole with a bushing at the top of the carb throttle lever. That will make it require more travel to get to wide open throttle than the factory carb had. There should be a smaller hole below the large hole. It should be easy to bend some rod stock that is the same size as the holes in the factory lever and the carb throttle lever. Then use two factory style clips to hold the rod on.
There won't be a factory linkage rod the correct length if you change carburetor styles.
Sal
scicala is offline   Reply With Quote
Old 03-03-2021, 09:27 PM   #7
55blacktie
Although I expect criticism, you could eliminate the complex throttle assembly and use a Lokar pedal and cable.
55blacktie is offline   Reply With Quote
Old 03-03-2021, 10:32 PM   #8
dmsfrr
dmsfrr's Avatar
ChadCurrent,
Does the car have a Manual or Automatic transmission?
Old 03-04-2021, 06:36 PM   #9
scicala
scicala's Avatar
Originally Posted by dmsfrr View Post
ChadCurrent,
In the video it looked like a Fordomatic bell crank, but no rod attached going to the trans.
Sal
Old 03-04-2021, 07:57 PM   #10
ChadCurrent
Borg warner t10 4 speed
Old 03-04-2021, 08:09 PM   #11
ChadCurrent
It's a pain around here as no one has piles of parts lying around so I have to hunt down ideas online and try to make sense of it and try to buy the parts. I am pretty sure I can make something work. I found a universal throttle rod at classic auto industry's I might be able to trim down and bend something that will work.
I had no idea what a lokar pedal and cable was. I might investigate it some. Possibly in the future I'd like to find a 57 intake and 57 tbird carburetor, a distributor with the tach drive and a mechanical tach to get a little closer to the original year but I'm gonna have to wait until this covid stuff ends and swap meets return.
Old 03-04-2021, 08:36 PM   #12
paul2748
paul2748's Avatar
Get some small rod ends and thread some rod the length you need
48 Ford Conv
56 Tbird
54 Ford Victoria
paul2748 is online now   Reply With Quote
Old 03-04-2021, 08:43 PM   #13
paul2748
paul2748's Avatar
Get some small rod ends and thread some rod the length you need. That is what I did on my 54 Ford (312 with toploader)
Maybe look for some standard shift linkage off a Bird?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-05-2021, 01:11 AM   #14
KULTULZ
KULTULZ's Avatar
Question Re: Finally running after 50 years
Possibly in the future I'd like to find a 57 intake and 57 tbird carburetor ...
I think you described the build details in a previous post. What year BIRD and what year engine?
Read This - https://www.fordmuscle.com/archives/...kage/index.php
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 03-06-2021, 03:03 AM   #15
JeffB2
JeffB2's Avatar
https://lokar.com/throt-cable-kickdowns.html
JeffB2 is offline   Reply With Quote
Old 03-09-2021, 07:08 PM   #16
ChadCurrent
It's a 56 tbird, I have no idea what year the engine is? Just a 292 and a free old intake manifold my uncle gave me.
Old 03-09-2021, 07:55 PM   #17
55blacktie
Chad, I purchased the Lokar pedal for my 55 T-bird. I'm keeping the 292 but converting to a C4 transmission. I will use the Lokar throttle and kickdown cables as well. I have a Holley 1850 Street Avenger 570 carburetor on a 57 "B" manifold. Lokar has 2 pedals. I chose the one that most resembles the stock pedal. It did require cutting a hole in the firewall, about 3/4" above where the floor meets the firewall. I used a 2" cut-off wheel to make the hole. You can look at the pedal choices and installation instructions on Lokar's website. If you go this route, don't discard your original bellcrank assembly (or any OEM parts for that matter).
Old 03-09-2021, 10:27 PM   #18
miker98038
miker98038's Avatar
I used one of these Lokar units. 2 bolts thru firewall, 1 above for the cable. Part of my reason is the floor pan was so rough under the original throttle pedal. T-5, so no other linkage or kickdown switch necessary.
https://www.speedwaymotors.com/Lokar...ber,64528.html
Old 03-10-2021, 03:37 AM   #19
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Finally running after 50 years
AMEN! to that ...
- WHY IS IT ... -
Old 03-10-2021, 11:39 AM   #20
scicala
scicala's Avatar
The intake in the video appears to be ECZ-A, which is an original manifold for '56 Ford, T-Bird and Mercury with the small base 4 barrel carb. (292 & 312).
Sal
