Old 07-30-2021, 11:55 AM   #1
Russell Reay
Default Control arm positions
In a recent post by Stevie649 there are photos of his 1928 steering column clearly showing the control arms, presumably at rest. Looking rearward toward the steering wheel, the two arms are in the 1 to 2 o'clock positions. I have done fair battle with my control rods and arms (1930) and mine both point to 12 o'clock when both rod levers are full up in the start position. While my steering tube is still on the bench, what is the correct position of the arms ?
Russell Reay is offline   Reply With Quote
Old 07-30-2021, 06:13 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Control arm positions
this work?
www.whidbeymodelaclub.com
Old 07-30-2021, 07:02 PM   #3
Russell Reay
Yours are the same as Stevie's. Now I know what to shoot for. Thanks.
Old 07-30-2021, 09:04 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I think without being attached to their devices, they may over extend their reach a bit. On the two tooth, you can rotate a bit for final adjustments. Some rods are not the right length, which causes problems.
Old 07-31-2021, 07:50 AM   #5
Russell Reay
I am just re-assembling original parts, but with new springs, pins, and top bushing.
Old 07-31-2021, 08:09 AM   #6
Big hammer
The steering colunm clamp on top of the two tooth gear box is where you can adjust the control rod lengths.......and if you don't tighten the clamp after adjusting the gear box you( me) will be doing it over! I had too, once.
get a bigger hammer tap done
