Old 12-01-2021, 03:21 PM   #1
60ch
Default flow testing Model A Zenith carb jets
Can anyone explain the reason for flow testing Model A Zenith carb jets with a 36 inch water column instead of the 37 1/4inch column as used by Ford? Thank you.
60ch is offline   Reply With Quote
Old 12-01-2021, 08:12 PM   #2
Gary WA
Gary WA's Avatar
Default Re: flow testing Model A Zenith carb jets
here u go.
www.whidbeymodelaclub.com
Old 12-02-2021, 08:22 AM   #3
Kevin in NJ
Here are some charts to make life easy.
http://www.fordgarage.com/pages/jetflowrates.htm
I tested many jets using the Ford column length.
I did a lot of error checking and repeating and found the results were very consistant.
Most seemed to flow too much by a little to a lot and some were on the money. A few did not have a nice stream indicating there was a problem with the hole and flow.
Old 12-02-2021, 06:19 PM   #4
JD 1931
JD 1931's Avatar
I have rebuilt and sold over 200 model A zenith carbs and have always gone by the drill size for all the jets...Merry Christmas
JD 1931 is offline   Reply With Quote
Old 12-04-2021, 02:39 PM   #5
redmodelt
redmodelt's Avatar
One thing I have seen someplace is; when soldering the hole up to resize, how thick the solder is before you redrill the hole can change the rate of the flow. So if it calls for X size hole, might have to go to larger or smaller drill to get the correct flow.
Old 12-04-2021, 05:02 PM   #6
mercman from oz
mercman from oz's Avatar
Technical Note on Flow-Testing - Gary WA
