10-15-2021, 03:51 PM | #1 |
1940 wiper motor
Is it possible to lube the motor without taking it apart, mine cycles but sticks once in a while ?
thanks kurt |
10-15-2021, 05:20 PM | #2 |
Re: 1940 wiper motor
I got it working, couple drops of 3&1 oil in tube now it works good.
10-16-2021, 07:03 AM | #3 |
A little Marvel Mystery Oil will also do the trick.
10-16-2021, 10:27 AM | #4 |
Sticks? If at the extremes the problem is most likely in the small metal cover. There is a switching device that moves to switch the vacuum so the motor can reverse. The switching device can stick or hang up.
10-17-2021, 03:53 AM | #5 |
